  3. Schematic Pcell - Evaluation Callback?
  • Views 2665
kdolan
kdolan over 2 years ago
I'm currently working on a schematic PCell and facing an issue with the schematic not being 'Checked and Saved' at the correct time.
I have something like the following:
mySchPcell = pcDefinePCell(
... Pcell definition ...
);pcDefinePCell
schCheck(mySchPcell)
dbSave(mySchPcell)
dbClose(mySchPcell)
This was originally working, but now I have introduced CDF callbacks that have the potential to change the schematic Pcell and its parameters. Since this, I now have the error whereby it seems my schematic is not being checked and saved after all edits have been made and the pcell is fully evaluated.
I have tried moving the schCheck command within the Pcell definition function, but this leads to streamout issues as it says this function is now undefined.
Is there a PCell evaluation callback or something similar, whereby every time the schematic pcell is evaluated and placed, that it will trigger a check and save of the created pcell instance? Or, is there a better or more correct approach to this in which I might be missing?
Thanks!
Keelan
  • skillUser
    skillUser over 2 years ago
    Hi Keelan,
    The Schematic Check & Save is responsible for extracting connectivity (and saving) but when you create a Schematic PCell you are responsible for creating the (correct) connectivity, and you should not use any 'sch' prefix functions inside a PCell (technically yours is outside but it is still not recommended) - but there is a way to mark it as 'checked' or 'up to date' - you can use
    dbSetConnCurrent(cvId)
    inside the pcDefinePCell statement.  Hopefully this helps you.
    Best regards,
    Lawrence.
    Andrew Beckett over 2 years ago in reply to skillUser
    Following from Lawrence's comments, actually there is no need to call dbSetConnCurrent within a PCell, and you certainly can't run schCheck() within a PCell (I didn't understand the comment about stream out since you can't stream out a schematic PCell...). Running schCheck() outside the PCell makes no sense either because that would only check the superMaster which is not used for anything other than displaying when you open the cellView directly.
    Why are you trying to run schCheck? If it's to extract the connectivity, you can't do that. You are responsible for creating the connectivity in the PCell - and the reason why the dbSetConnCurrent is not required is that there's an assumption that if the connectivity was created by code, it must be up to date.
    Anyway, Keelan, if you are the Keelan Dolan I believe you are, your company has access to PCell Designer; creating schematic PCells using PCell Designer is much simpler and avoids having to worry about these things. Can you use PCell Designer instead? If you're unsure, please contact me directly (if you don't know my email address, send me a friend request here and we can get in touch; note, this is not an invitation to others to do the same - I generally decline friend requests as mostly people use them as a way to bypass the forums and talk to me directly, for which I don't have the bandwidth).
