  3. Custom menu in Explorer GUI is removed when simulator is...
  • Views 7391
Custom menu in Explorer GUI is removed when simulator is changed
marcelpreda
marcelpreda over 2 years ago
Hi there,
We are creating a submenu under "Tools" menu in the Explorer window, using something like
deRegUserTriggers(app nil nil myProc)   where app="explorer".
Everything works fine, until users change the simulator (they may choose the wrong one at the beginning or whatever reason), in this moment our menu entry is removed.
Also I've noticed that "Tools" submenus are different from simulator to simulator (see screenshot), so I assume that there is some trigger on "change simulator" event.
Any idea what is the event, and how we can set a callback procedure so that we add our menu entry if necessary?
Thank you,
Marcel
Below the menus entries for few simulators
    The right way to do this is to use menus files rather than an a de trigger.
  • marcelpreda
    marcelpreda over 2 years ago in reply to Andrew Beckett
    Thank you for the reply.
    Never used menus files, I had a look on .../dfII/etc/tools/menus/ files and I've understood how it works.
    Unfortunately I have no control on the menus files.
    My use case is next one: we have an inhouse tool (skill context) that is enabled or not in user environment, so the menu entry has to be created dynamically. My hope was that there was a trigger also for "change simulator" event (or whatever it is).
    Thank you,
    Marcel
    Andrew Beckett over 2 years ago in reply to marcelpreda
    Marcel,
    Maybe you could use axlSessionConnect with "updatedTest" as the signal. This is triggered more frequently than just a simulator change, but maybe you could use that to determine whether the menu is present and if not add it again?
  • marcelpreda
    This seems to be the best approach in my case.
    I've also had a look on the axlSessionSignalList documentation, and I have to select the proper signal(s) .
    Thank you,
    Marcel
    Hi Marcel,
    I did a quick test yesterday to see which signals were fired when the simulator name is changed, and updatedTest is the best option. I then further tested it using this as the trigger function:
    (defun abUpdatedTest (sess testName)
      (letseq
        ((sevSess (axlGetToolSession sess testName))
         (asiSess (sevEnvironment sevSess))
         (simName (asiGetSimName asiSess)))
        (printf "Sim Name is %s\n" simName)
    (axlSessionConnect (axlGetWindowSession) "updatedTest" 'abUpdatedTest)
    (of course, you'd probably use axlSessionRegisterCreationCallback to register a callback to then do the axlSessionConnect after the session has been created).
