  3. skill command for Fractures edges of the specified object...
  • Views 6449
skill command for Fractures edges of the specified object on the input list into horizontal trapezoids.
Rishabh27
Rishabh27 over 2 years ago
Hi ,
I want to cut this metal horizontally , I was using dbLayerTile commnad for breaking it but it is breaking vertically .
can anyone please help me with  the skill command or code for this part.
thanks,
  • AurelBuche
    AurelBuche over 2 years ago
    You can do something like:
    procedure( split_in_tiles( @key (objects   geGetSelectedSet())
                                    (direction "horizontal")
      "Split OBJECTS in tiles according to DIRECTION"
      assert( member(direction '("vertical" "horizontal"))
        "Direction should be \"vertical\" or \"horizontal\"")
      unwindProtect(
        ;; Start ABE
        let( (lay iter tile)
          cv = car(objects)->cellView
          abeInit(cv)
          ;; Create an ABE layer from object
          ;; Merge its tiles according to direction
          foreach( obj objects
            when( obj->isShape
              lay = abeLayerFromShapes( setof(obj objects obj->isShape))
              abeLayerMergeTiles( lay direction)
              ;; Browse generated tiles, create associated rectangles
              iter = abeTileIterator( lay )
              while( tile = iter->next
                dbCreateRect( cv obj->lpp tile->bbox )
              ;; Delete splitted shape
              dbDeleteObject(obj)
            );foreach
          );let
        abeDone()
    Cheers,
    Aurélien
    Andrew Beckett over 2 years ago in reply to AurelBuche
    Aurélien's suggestion is the best approach, I'd say (that's what I was going to propose), but for completeness there's How can I do horizontal slicing using leSlice and horizontal tiling using dbLayerTile SKILL function
