  3. Question about Making several 'dbCreateRect's into one ...
  • Views 2136
Question about Making several 'dbCreateRect's into one group
Andy kim
Andy kim over 2 years ago
Hi
i'm making one fuction about drawing gate_contact easily.(only for a specific part)
( * i'm beginner to skill language but i want to be a of help to my team)
let(
(cv rect1 rect2 rect3 rect4 fg)
cv=geGetEditCellView()
rect1=dbCreateRect(cv list("PO" "drawing") list(list(X X) list(X X)))
rect2=dbCreateRect(cv list("CO" "drawing") list(list(X X) list(X X)))
rect3=dbCreateRect(cv list("PP" "drawing") list(list(X X) list(X X)))
rect4=dbCreateRect(cv list("M1" "drawing") list(list(X X) list(X X)))
fg=dbCreateFigGroup(cv "myFigGroup1" nil lowerLeft(list(rect1 rect2 rect3 rect4)~>bBox) "R0")
dbAddFigToFigGroup(fg list(rect1 rect2 rect3 rect4))
dbSave(cv)
) ; let exit
the problem is that the shape appears, but isn't grouped together.
please help me ; <
Andy.Kim
    Andrew Beckett over 2 years ago +1
    Andy, There are two issues here: fg=dbCreateFigGroup(cv "myFigGroup1" nil lowerLeft(list(rect1 rect2 rect3 rect4)~>bBox) "R0") will result in: *Error* dbCreateFigGroup: Invalid point - ((0.0 0…
    Andy,
    will result in:
    *Error* dbCreateFigGroup: Invalid point - ((0.0 0.0) (1.0 1.0))
    That's because the list(rect1 rect2 rect3 rect4)~>bBox will return a list of bBoxes for each of the rectangles, but lowerLeft will simply return the first of these boxes (which is not a point). lowerLeft won't return the lower left-most corner of a list of bounding boxes. Anyway, since the origin of the figGroup is not that critical, you could just use:
    fg=dbCreateFigGroup(cv "myFigGroup1" nil lowerLeft(rect1~>bBox) "R0")
    Fixing that will lead to another error:
    *Error* dbAddFigToFigGroup: argument #2 should be a database object (type template = "dd") - (db:0x2761bd1d db:0x2761bd1c db:0x2761bd1b db:0x2761bd1a)
    which is because dbAddFigToFigGroup doesn't accept a list as the second argument. So instead:
    foreach(fig list(rect1 rect2 rect3 rect4)
        dbAddFigToFigGroup(fg fig)
    will do what you want.
  • Andy kim
    Andy kim over 2 years ago in reply to Andrew Beckett
    Thank you so much. Reply!
    I'm encouraged to proceed with the assignment!
    I'll make sure to finish it : )
    Andy.Kim
