  3. system() function is executed before other instructions...
  • Views 6532
LoVyacheslavvVEMs
LoVyacheslavvVEMs over 2 years ago
Hello!
While writing code on SKILL, I found one roblem. Here is its representation in a simplified example:
procedure( test()
println(1)
println(2)
println(3)
println(4)
println(5)
system("sleep 4")
);procedure test
As a result of executing this code, I get 4 seconds of waiting for the execution of the system("sleep 4") command, and after that the results of the execution of println and system commands:
1
2
3
4
5
0
What could be the reason for this behavior of SKILL and how can I make println() run first?
Advance thanks!
    Call hiFlushCIW() or hiFlushInfo() before the system() call. It's not that the other functions are executed after the system() call - it's that the output is buffered and doesn't get flushed when the UI is blocked by the system() call.
  • LoVyacheslavvVEMs
    LoVyacheslavvVEMs over 2 years ago in reply to Andrew Beckett
    Thanks a lot, Andrew, for the quick response!
    It worked great!
