  3. how to pass argument in user defined procedure function...
  • Views 8382
how to pass argument in user defined procedure function on pull-down menu skill code.
yogeshjaiswalCAD
yogeshjaiswalCAD over 2 years ago
Dear Group members ,
I need small favor from your expertise,  Please help me on  how to pass argument in user defined  procedure of pull-down menu.
I have tested following pulldown skill code
procedure(AmitAddMenu(args)
let( (item1 item2)
;; create a couple of menu items
item1 = hiCreateMenuItem( ?name 'item1 ?itemText "My First Item" ?callback "AmitFunctionOne()" )
item2 = hiCreateMenuItem( ?name 'item2 ?itemText "My Second Item" ?callback "AmitFunctionTwo()" )
;; create a menu that includes the menu items and return a list of the
;; pulldown menus
list(hiCreatePulldownMenu('AmitMenu "Amit Menu" list(item1 item2)))
);let
); procedure
;; create a userMenuTrigger trigger that automatically adds the menu
deRegUserTriggers("maskLayout" nil 'AmitAddMenu)
Please help me with following query
For example : How to pass argument to different argument to user skill function in pulldown menu
AmitFunctionOne( "meatl2" .08)   let say two arguments are "meatl2" .08
AmitFunctionTwo(" Via1"  .09)        let say two arguments are "Via1" .09
Thanks for your help again !
Best regards,
Yogesh Jaiswal
USA
  • yogeshjaiswalCAD
    please post you suggestion or code , how to proceed
  • AurelBuche
    AurelBuche over 2 years ago in reply to yogeshjaiswalCAD
    Hi Yogesh,
    I am not sure to understand your question,
    If you want to pass the arguments directly, you can type them in the callback string:
    item1 = hiCreateMenuItem( ?name 'item1 ?itemText "My First Item" ?callback "AmitFunctionOne(\"meatl2\" .08)" )
    If you want the user to be able to select those arguments you will have to build a custom interface
    There might be other solutions to provide variables inside a string callback (global variables, SKILL++, etc.) but you need to clarify the use case for our answers to be pertinent
    Cheers,
    Aurélien
  • yogeshjaiswalCAD
    yogeshjaiswalCAD over 2 years ago in reply to AurelBuche
    greetings Aurélien,
    many thanks for you reply , I want the user to be able to select those arguments from outside which needs  build of custom interface for example
    There might be other solutions to provide variables inside a string callback.. if you can share any such custom interface where i can pass such 2 or more argument ..for ease let say i want to pass  metal2 and .08 from user interface. Please help me on this.
    many thanks again
    cheers,
    yogesh
  • yogeshjaiswalCAD
    yogeshjaiswalCAD over 2 years ago in reply to yogeshjaiswalCAD
    please share your view or code for above issue , thanks in advance
  • AurelBuche
    Hi Yogesh,
    Usually you create a GUI function to display the form and you use your main function in the form callback :
    procedure( AmitFunctionOne_gui( @rest _args)
      "Display a GUI to provide parameters to `AmitFunctionOne' and run it"
      hiDisplayForm(
        hiCreateLayoutForm( 'AmitFunctionOne_form "Custom Form"
          hiCreateFormLayout( 'main_layout
            ?items
            list(
              hiCreateStringField( ?name 'layer  ?prompt "Layer"  )
              hiCreateFloatField(  ?name 'number ?prompt "Number" )
          ?callback
          lambda( (form)
            ;; Fetch form values and call main function
            AmitFunctionOne( form->layer->value form->number->value )
    In the menu you call the GUI function :
    item1 = hiCreateMenuItem( ?name 'item1 ?itemText "My First Item" ?callback "AmitFunctionOne_gui()" )
    Cheers,
    Aurélien
  • yogeshjaiswalCAD
    Many Thanks Aurélien ,
    I mean it , you took personal time to share perfect solution in simplest way. I was looking for the same.
    Have a Great Day & Stay Blessed !
    Cheers,
    Yogesh
    USA)
