  3. Cadence form SKILL Code
  • Views 8034
STrib
STrib over 2 years ago
Can Someone provide me a code on how to change the size of a form depending on the options chosen from a radio button and print it in a file. Like if I click radio button 1 -> 4 string field will appear, if I click radio button 2 3 string field will appear and if I click radio button 3 no string field will come. Also I need to print the above values given by the user from the form.
    Probably you'd want to use a more sophisticated layout for your actual form (I used hiCreateFormLayout, but maybe hiCreateGridLayout would be better - see other examples on this forum).
    Anyway, a very quick thrown-together example.
    procedure(CCFradioExampleCreateForm()
      hiCreateLayoutForm(
        'CCFradioExampleForm
        "Radio Example Form"
        hiCreateFormLayout(
          'lay
          ?items list(
            hiCreateRadioField(
              ?name 'radio
              ?prompt "Choose"
              ?choices list("1" "2" "3")
              ?defValue "1"
              ?callback list("CCFradioCB(hiGetCurrentForm())")
            hiCreateStringField(
              ?name 'string1
              ?prompt "String 1"
              ?name 'string2
              ?prompt "String 2"
              ?name 'string3
              ?prompt "String 3"
              ?name 'string4
              ?prompt "String 4"
        ?callback 'CCFradioExampleCB
    procedure(CCFradioCB(form)
      let((visiblity)
        visibility=case(form->radio->value
          ("1" list(t t t t))
          ("2" list(t t t nil))
          ("3" list(nil nil nil nil))
        foreach((field vis) '(string1 string2 string3 string4) visibility
          get(form field)->invisible=!vis
    procedure(CCFradioExampleCB(form)
      printf("Radio: %s\n" form->radio->value)
      printf("String1: %s\n" form->string1->value)
      printf("String2: %s\n" form->string2->value)
      printf("String3: %s\n" form->string3->value)
      printf("String4: %s\n" form->string4->value)
    procedure(CCFdisplayRadioExample()
      unless(boundp('CCFradioExampleForm)
      hiDisplayForm(CCFradioExampleForm)
