  3. Getting a list of all existing SKILL functions
  • Views 9237
LoVyacheslavvVEMs
LoVyacheslavvVEMs over 2 years ago
Hello.
My company uses text editors to write the SKILL code. For myself, I chose to use Sublime Text, and for convenience, I want to write my own syntax highlighting. For pop-up completions when writing a function, I want to get a list of all existing SKILL functions, however, I have not found a way to do this.
Can I get a list of all existing SKILL functions and how to do it?
Thanks!
  • p94todorov
    p94todorov over 2 years ago
    I still may think that trying to have highlighting for all SKILL functions is an overkill, because it is unlikely that you need more than a couple of hundred of them, you might be able to list them with such a command in the CIW:
    functions = setof(args mapcar('lambda((x) car(errset(arglist(x)))) oblist) args != 'unknown)
    I would at least filter them on the "_" and "__" prefixes to drop all internal functions, because for my current session this has returned more than 83000 functions...
    I am using a custom Gedit highlighting scheme, but it was more or less more manually created and I update it with my own functions as well. I think it would be better idea to list several functions families independently using regex and then combine them in your needed file:
    listFunctions("^db.+")
    Petar
  • AurelBuche
    AurelBuche over 2 years ago
    If you want to get the list of public, documented functions (with their arguments, docstrings, etc.)
    You can parse .fnd files in Cadence Virtuoso Root  (simplifyFilename (strcat (car (getInstallPath)) "/../../doc/finder"))
    You can also parse .fnd files in (getenv "CDS_FINDER_PATH") [if any].
    Cheers
    Aurélien
