  3. Skill script for push up and pull down the sub blocks to...
  • Views 6200
Skill script for push up and pull down the sub blocks to next level of layouts and vise versa
Saitsk
Saitsk over 2 years ago
Can any one help me out the script for pull down and push up.
Push up the sub blocks to next level of layouts and
Pull down the sub blocks from top level to below levels.
  • RobMan
    RobMan over 2 years ago
    "Push up" - This is equivalent to flattening hierarchy from the level above. Is this not an option?
    "Pull down" - This is equivalent to the level above.... unless you want to "pull" selective instances?
    Either operation is obviously not viable in a cellview in isolation. The context must be known i.e. Descended through the hierarchy so the cellview above is known.
    I would have to ask why you want to do this? Complications will arise with XL compliance; not insurmountable but I would recommend you try to maintain.
