  3. Stacked vias
  • Views 8121
Stacked vias
Shivani Lahariya
Shivani Lahariya over 2 years ago
I am trying to create via stack by identifying the metals and placing the required via at particular location. Can someone help me with this.
Shivani
    Andrew Beckett over 2 years ago in reply to Shivani Lahariya +1
    Shivani, Yes. Use: myViaOptions->automatic->minNumCuts=2 Andrew
    Have you looked at using the "via" SKILL functions? These begin with "via" (so search in cdsFinder for "via" and check the "Match beginning" checkbox).
  • Shivani Lahariya
    Shivani Lahariya over 2 years ago in reply to Andrew Beckett
    Thanks for the response Andrew. I looked into two options.
    Option1:
    shapes=geGetSelSet()
    cvId = geGetEditCellView()
    tech = techGetTechFile(cvId)
    constraintGroupId = cstFindConstraintGroupIn(tech "virtuosoDefaultSetup")
    myViaOptions = viaGetViaOptions(constraintGroupId)
    viaGenerateViasFromShapes(cvId shapes myViaOptions)
    Option2:
    viaDefId = techFindViaDefByName(tech "met2_met1")
    viaParams = list(list("cutRows" 1) list("cutColumns" 2))
    newVia = dbCreateVia(cvId viaDefId list(5 5) "R0" viaParams)
    But I want to define cutRows and cutColumns in first option. Basically, I want to create via with metal overlap but with minimum two vias. First option just provides single cut via.
    Shivani
  • Shivani Lahariya
    Shivani Lahariya over 2 years ago in reply to Shivani Lahariya
    Is it possible to modify via Options? that might serve the purpose.
    Shivani
    Shivani,
    Yes. Use:
  • Shivani Lahariya
    It worked. Thank you
    Shivani
