  3. Not able to run assura LVS from command line
  • Views 5980
mibrahim
mibrahim over 2 years ago
hello everyone
I have been trying to assura LVS from the command line but it throws an error saying   *.vlr does not exist.but if I run it once using the GUI and then run it it works fine
how do I generate the .vlr file if that is required to run LVS through command line
thank you
    This article should help - How to run Assura LVS via the command line with dfII layout and schematic from different libraries? (you may not have different libraries, but it explains the principles nevertheless)
