  3. Got Error Message when I use schCheck with sstatus(errsetTrace...
  • Views 1292
Got Error Message when I use schCheck with sstatus(errsetTrace t)
AllenCheng
AllenCheng over 2 years ago
Hi Sirs,
When I use schCheck(CV) to do check&save in my script, I got error mesages below.
schCheck(CV)
*Error* hiSetProgressBar: argument #1 should be a window type (type template = "wx") - nil
<<< Stack Trace >>>
(... in _schProgressBarStep ...)
processed = nil
win = nil
step = 12
item = 1
numberOfItems = 1
(... in _schSetBatchProgressBar ...)
step = 12
numberOfSteps = 12
item = 1
numberOfItems = 1
apply('_schSetBatchProgressBar '(12 12 1 1))
(... in schExtractConn ...)
nError = nil
nWarn = nil
result = nil
errL = nil
sumErrors = 0
sumWarns = 0
sheetCV = nil
sheetInst = nil
sheetList = nil
errMsg = nil
severity = nil
msgPrefix = "Extracting"
checkAll = nil
inGraphics = t
id = nil
didList = nil
checkHierIgnoreNeedCheckout = nil
runPreCheckTrigs = t
cv = db:0x2f20f71a
(... in schCheck ...)
result = nil
result1 = nil
result2 = nil
nError = nil
nWarn = nil
userErrorWarn = nil
totalError = nil
totalWarn = nil
cvId = db:0x2f20f71a
I found when I set sstatus(errsetTrace t) I got those mesage. I can set sstatus(errsetTrace nil) to make all error messages disappeared.  However, do I have any other way to make there is not any error message?
Thanks.
    Well, sstatus(errsetTrace t) is not the default, and intended to be used to help debug issues when an error is caught. In this case an error is intentionally caught, so if you've forced it to display a stack trace when an error is caught that's really down to your choice to display that information!
    There doesn't seem to be another switch to stop it trying to update the progress bar - instead it uses a try/catch type approach for this - if it fails, the error is caught.
