  3. How to change the pin direction in the schematic
  • Subscribers 152
  • Views 6806
jarry37
jarry37 over 2 years ago
Tell me the skill code that can change the direction of all pins at once in the schematic.
I want to change the input direction pins to output direction, and output direction pins to input direction.
Please tell me the skill syntax that can change all at once.
And tell me how to add pins by reading a text file.
The text file is written in the format of <pin name> <pin direction>.
Since the number of pins ranges from tens to hundreds, it's difficult to enter all, so I'm asking for it.
  • skillEater
    skillEater over 2 years ago
    Hi jarry,
    you can change the direction of the pins as per your requirement with below skill code.Please let me know if you have any issues.
    procedure(pinDirectionChange()
    let((cv direCtion)
    cv=geGetEditCellView()
    foreach(pIn cv~>instances
    direCtion=pIn~>pin~>term~>direction
    when(direCtion=="input"
    pIn~>pin~>term~>direction="output")
    when(direCtion=="output"
    pIn~>pin~>term~>direction="input")
    hiSetBindKey("Schematics" "<Key>r" "pinDirectionChange()")
    I do not understand your second requirement.Please let me know in detail if you still have the issue.
    Regards
    Ganesh Doddipatla.
