  3. Pcell symbol with curved shapes using dbCreateArc faili...
  • Views 7350
Pcell symbol with curved shapes using dbCreateArc failing
rglenf
rglenf over 2 years ago
I am trying to create a pcell symbol with small curved shapes.  When using dbCreateArc, I am constantly getting - *WARNING* (DB-270000): dbCreateArcByBBox: The arc bounding box incorrectly intersects the ellipse bounding box.  I cannot seem to find any information on how to correct this.
Sample code:
cv = geGetEditCellView()
lineLayer = '("device" "drawing")
arc1 = dbCreateArc(cv lineLayer list(0.08125:0.1375 0.13125:0.1875) list(0.08125:0.1375 0.1125:0.1875))
Any suggestions?
-Glen
    Glen,
    The issue is that arcs are (I believe) limited to a maximum of 180 degrees, and this would result in a longer arc than 180 degrees. The error message (which comes from OpenAccess) doesn't make this terribly clear; I've requested that the documentation is improved to make the 180 degree limit clear and also to mention what might trigger this error message.
  • rglenf
    rglenf over 2 years ago in reply to Andrew Beckett
    Andrew,
    Thanks for the reply.  I discovered that the ellipse bbox and the arc bbox can only overlap on 1 or 2 edges.  My call was overlapping on 3.  This is consistent with your comment about a maximum 180 degree.  I'd say that is more like just under 180 degree as 180 would require 3 edge overlap.  Once I pulled back the arc bbox to only overlap 2 sides, it worked.
    Thanks for your response.
    -Glen
    Andrew Beckett over 2 years ago in reply to rglenf
    Hi Glen,
    Actually, you can have a 3 edge overlap if it ends up being a narrow region of one end of the ellipse box (I tried this). For example - the white box is the ellipse box, the yellow is the arc box:
    There are a few other failure modes that can result in the error message (for example, a zero-area rectangle for the arc box), but the main one appears to be due to the angle constraint.
  • rglenf
    Andrew,
    Interesting.  I re-entered my original command, which failed.  I then reduced the x(UR) of the arc bbox until it worked.
    Original: dbCreateArc(cv lineLayer list(0.08125:0.1375 0.13125:0.1875) list(0.08125:0.1375 0.1125:0.1875))
    Worked: dbCreateArc(cv lineLayer list(0.08125:0.1375 0.13125:0.1875) list(0.08125:0.1375 0.1093:0.1875))
    It seems the 0.1125 is just over half of the x of the ellipse bbox.  Half would be (0.08125:0 + 0.13125) / 2 = 0.10625, within the working range of the arc bbox.
    Thanks for the insight.
    Glen
