  3. Where is the documentation for the Core Skill function ...
  • Views 1812
Where is the documentation for the Core Skill function "makeArray()" ?
Daedalus
Daedalus over 2 years ago
I am having trouble finding the documentation for makeArray using the Cadence SKILL API finder or user manual. I know it exists because the interpreter in the CIW recognizes it and it appears to declare multidimensional arrays. Ultimately, I would like to make a 2D array of booleans, and this function seems like a clean way to do it.
    Andrew Beckett over 2 years ago +1
    It's a private function (very old, and before we were strict about the naming of private versus public functions), and hence not documented. You should not use it. Here's an example implementation of…
    Here's an example implementation of a function to create a multidimensional array easily though:
    /* abMultiDimArray.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Nov 23, 2009
    Modified
    By
    Function for creating a multi-dimensional array.
    Usage:
    data=abMultiDimArray(6 8)
    Creates a 6 by 8 array (starting index is from 0). Then you can use:
    data[4][5]=23
    data[0][7]=123
    You can specify more dimensions by passing more arguments to abMultiDimArray.
    SCCS Info: @(#) abMultiDimArray.il 11/23/09.16:24:27 1.1
    procedure(abMultiDimArray(@rest dimensions)
        let((arr)
            if(integerp(car(dimensions)) && plusp(car(dimensions)) then
                arr=makeVector(car(dimensions))
                when(cdr(dimensions)
                    for(ind 0 sub1(car(dimensions))
                        arr[ind]=apply('abMultiDimArray cdr(dimensions))
                ) ; when
                arr
            else
                error("Dimension %L must be a positive integer\n" car(dimensions))
            ) ; if
        ) ; let
    ) ; procedure
  • Daedalus
    Daedalus over 2 years ago in reply to Andrew Beckett
    Thank you for the response and code!
