  3. Dereferencing named output expresisons / Ouput Expression...
  • Views 5306
Dereferencing named output expresisons / Ouput Expression indirection
Volker T
Volker T over 2 years ago
Dear all,
in an ADE Explorer session, I use named output expressions, like
Name   Details
tspl       cross(<something>)
Assume I have access to the results data base by SKILL code, and specifically the output expressions as used in the ADE session, in the following example represented by object "output" for one of these output expressions.
Now I would like to use the output expression to calclulate its result. For simple, atomic expressions, this works fine.
Example:
output->name
> tspl
output->expression
> cross(<something>)
eval(output->expression)
> 0.0001
So far, so good (apart from the fact that usage of the eval() function is discouraged and there is probably a better way to evaluate the expression - if so, please let me know). However, this is not the point here.
The problem arises when I use "nested" named output expressions. Assume, I want to use named output expression "tspl" to now sample a waveform at the calculated time point.
In ADE, I define
Name   Details
vspl    value(<waveform> tspl)
Thereby, I have a named output expression that depends on another named output expression. This is what I mean with "nested" named output expressions.
Now, the simple call to eval() fails, because it cannot dereference variable name "tspl" by itself:
eval(vspl)
> *Error* eval: unbound variable - tspl
What I need is a function that creates an atomic expression by first dereferencing all named output expressions followed by evaluation of the resolved atomic output expression.
Does anyone know how to do this (or how to calculate (nested) named output expressions of an ADE session by SKILL in a more elegant way?
Thank you very much.
