  3. Signal type
  • Views 8022
Signal type
Aldo3
Aldo3 over 2 years ago
For the i-th terminal of an instance
nth(i cv~>terminals)~>term~>net~>sigType
gives the signal type set in the "Create Pin" gui.
How is net~>sigType set?
nth(i cv~>terminals)~>net~>sigType
Thank you
Best regards
Aldo
    Aldo,
    Just use (say) net~>sigType="supply" or net~>sigType="signal" . Note that the signal types are not exactly the same as they are shown in the edit properties form or property assistant. Search in the documentation for "Signal Attributes" (in quotation marks) and you'll find the reference for the allowed values.
  • Aldo3
    Aldo3 over 2 years ago in reply to Andrew Beckett
    Thank you Andrew for you kind support.
    I was writing a script to grab info about pins of the instances contained in a schematic.
    From the documentation I've seen that the same value I set in the "Create Pin" gui can be read through sigType:
    (except "power" in the gui, corresponding to sigType="supply").
    It is still unclear to me where the info contained in nth(i cv~>terminals)~>net~>sigType come from.
    There is a sigType associated to terminal's term~>net (the one I'm interested to know) and one associated to terminal's net (that can be different from the first one).
    Thank you
    Best regards
    Aldo
    Andrew Beckett over 2 years ago in reply to Aldo3
    OK, I've re-read your original question, and realise that you've used a variable cv which is actually an instance not a cellView (the importance of good naming of variables). If it had been a cellView, then cv~>terminals~>term would have returned a list of nils (because terminal objects on a cellView don't have a terminal attribute).
    Now that I've realised that you're talking about instances, then:
    inst~>terminals is an alias for inst~>instTerms (the terminals attribute is not shown when you do inst~>?). If you go from an instTerm and do inst~>instTerms~>term - you get the terminal on the instantiated cellView (a symbol if it's a schematic), and then if you do inst~>instTerms~>term~>net~>sigType you're getting the sigTypes from the instantiated symbol. If however you do inst~>instTerms~>net you're getting the nets in the schematic that the symbol is instantiated in - and hence this is a different object.
    The sigType can be set via the property editor, but it an also be set automatically at check-and-save time. This is controlled by the Options→Check form, the Set Signal Type from Net Name and Type Registration which is defaulted by the postProcNetSigTypes cdsenv variable (search in the documentation for this).
    There's also the registration of name to signal type mapping which is controlled by the ciRegisterNet function (search for that in the documentation).
  • Aldo3
    Thank you for the clarification and sorry for the misleading variable name
    Best regards
    Aldo
