  3. IC20 Rulers/Measurement Question
  • Views 1851
B Power
B Power over 2 years ago
Hi All,
Just wondering if anyone has a way of getting the current list of rulers/measurements drawn on a layout.
In IC20 when a drawn ruler/measurement is selected it appears that geGetSelSet()~>cellView gives a different db than the db of the shapes in the cellview.
Previously checking the markers in a cellview would list the ruler, but this appears not to be the case anymore.
Thanks for any help,
Barry.
  • skillUser
    skillUser over 2 years ago
    Hi Barry,
    Yes, you can access them as marker objects where the objType is "ruler":
    setof(obj geGetEditCellView()~>markers obj~>objType=="ruler")
    Hopefully this answers your question?
    Best regards,
    Lawrence.
    Andrew Beckett over 2 years ago in reply to skillUser
    Hi Barry,
    There are two types of ruler (called "measurements" these days). What are called "Savable" measurements which are stored within the cellView, and non-savable (or transient) measurements which are saved in a temporary alternative cellView. By default the saveable measurements are orange, and the transient measurements are red. Lawrence's way will get all the saveable rulers; I don't think there's a way to get all the transient rulers though (which are stored in an in-memory scratch cellView, as you've found by selecting them).
    The type of measurement is indicated on the F3 options form when creating a measurement. This hasn't changed in many releases, so it's not just ICADVM20.1
