  3. multiple pins on same nets. Router is only routing 1 pin...
  • Subscribers 152
  • Views 7119
multiple pins on same nets. Router is only routing 1 pin. How to get router to connect all?
rickydua
rickydua over 2 years ago
Hi, I am using VSR router to route my design. I noticed for certain layout cells, there are multiple pins on same nets. Router is only routing 1 pin. How to get router to connect all?
    You almost certainly need to set up must connects on the pins. See these two short videos:
    • Virtuoso Pin Connectivity Model - Must Connect Pins
    • Virtuoso Pin Connectivity Model - Must Connect All Pins
  • rickydua
    rickydua over 2 years ago in reply to Andrew Beckett
    Thank you Andrew.
    I used below lines
    term=dbFindTermByName(cv "vcc_ceehv1")
    dbSetTermMustConnectAllPins(term t)
    is that any different from what those videos you shared directed?
  • rickydua
    rickydua over 2 years ago in reply to rickydua
    I do not see VSR router connecting those must joins at all with this approach dbSetTermMustConnectAllPins(term t)
  • rickydua
