  3. To open schematic view using bindkey irrespective of config...
  • Subscribers 152
  • Views 8092
To open schematic view using bindkey irrespective of config binding
Rishabmah
Rishabmah over 2 years ago
I want to create a bindkey so that I can descend in a particular schematic irrespective of what view I have set in related config. While using hiSetBindKey("Schematics" "<Key>J" "envSetVal(\"schematic\" \"descendTarget\" 'string \"use viewNameList\") schHiDescendRead()"), it opens the view set by config for that particular cell. Is there some way to open schematic view in read in similar fashion irrespective of config binding of the selected cell?
Rishab
    Andrew Beckett over 2 years ago in reply to Rishabmah +1
    You could (if you pre-select the instance) use: dePush(`(nil viewNameList ,schGetEnv("viewNameList") instanceName ,car(geGetSelSet())~>name) hiGetCurrentWindow()) That will descend using the viewNameList…
  • Rishabmah
    Rishabmah over 2 years ago in reply to Andrew Beckett +1
    Hi Andrew Thanks, this works. Using below command to open in read only mode. dePush(`(nil viewNameList ,schGetEnv("viewNameList") instanceName ,car(geGetSelSet())~>name) hiGetCurrentWindow() "r")
  • khanzain
    khanzain over 2 years ago +1
    To open the schematic view regardless of the current configuration binding for the selected cell, you can modify your bindkey script to explicitly specify the schematic view to open. Here's how you can…
  • AurelBuche
    AurelBuche over 2 years ago
    Hi Rishab,
    If you don't open the config view, but open the schematic directly,
    the descend edit default behavior should rely on viewList instead of config.
    But maybe you want to use this even when starting from a config view as top cellview ?
    Cheers,
    Aurélien
  • Rishabmah
    Rishabmah over 2 years ago in reply to AurelBuche
    Hi Aurélien,
    I need to use that bindkey when I am traversing using config view as top cellview.
    Rishab
    That will descend using the viewNameList entry as the preference. The next alternative would be to write a wrapper around this when checked if anything was selected and then used enterPoint to prompt you to click at a location.
    Or you might just want to contact customer support and ask for an enhancement to override the config rules with an argument (say) to schHiDescend (or a cdsenv).
  • Rishabmah
    Hi Andrew
  • khanzain
    To open the schematic view regardless of the current configuration binding for the selected cell, you can modify your bindkey script to explicitly specify the schematic view to open. Here's how you can do it:
    hiSetBindKey("Schematics" "<Key>J" {
    envSetVal("schematic" "descendTarget" "viewNameList")
    envSetVal("schematic" "viewNameList" 'list "schematic")
    schHiDescendRead()
    Explanation:
    1. envSetVal("schematic" "descendTarget" "viewNameList"): This line ensures that when you descend in the schematic hierarchy, it targets the view specified in the viewNameList environment variable.
    2. envSetVal("schematic" "viewNameList" 'list "schematic"): Here, we explicitly set the viewNameList to contain only the schematic view. This ensures that regardless of the current configuration binding, the schematic view will be opened when descending.
    3. schHiDescendRead(): Finally, we perform the descend operation to open the schematic view in read mode.
    By explicitly setting the viewNameList to contain only the schematic view, you ensure that the schematic view is opened regardless of the current configuration binding for the selected cell.
    Andrew Beckett over 2 years ago in reply to khanzain
    khanzain, this does not work. First of all, your bindkey is not a string (it will try to execute the group of functions immediately) and secondly you have omitted 'string from the first envSetVal. It should be (for example):
    hiSetBindKey("Schematics" "<Key>J" lsprintf("%L" '{
      envSetVal("schematic" "descendTarget" 'string "viewNameList")
      schHiDescendRead()
    However, even that doesn't work, because regardless of the desendTarget and viewNameList settings, if you are in a configured design, the bound view is used by default rather than the viewNameList. That was why the question was asked in the first place.
