  3. Hilite all schematic nets that do NOT have a user added...
  • Views 7349
Hilite all schematic nets that do NOT have a user added property...
vtboy51
vtboy51 over 2 years ago
For a variety of reasons we have added a property to certain schematic nets, and now I want to hilite the nets that do NOT have this property. This property could exist in our top level schematic or down the signal chain in a lower level cell, it just depends on where the Designer chose to tag the net. Because of this I need to scan each net, throughout the hierarchy looking for this property, and if no property exists (at any level) then hilite it at the top level schematic.
I found the schTraceNet function but don't fully understand the syntax to make it work. Below is what I have so far, but it doesn't work, and maybe the wrong direction. My thoughts are to set a userFlag to nil, scan through each net and if said property is found at any level of hierarchy change the userFlag=t and then hilite the net at the top level. Any tips are appreciated.
foreach(net cv~>signals
  userFlag=nil
  schTraceNet(?topCellView cv ?net net~>name ?traceCB 'rfLookForNetPropCB)
   when(userFlag
    geAddNetProbe(getCurrentWindow() list("y0" "drawing") net~>name)
   );when
);end foreach
procedure(rfLookForNetPropCB(netStruct)
 let(()
  when(car(car(netStruct->net~>allInstTerms~>net~>prop~>name)) == "netInfo"     ;netInfo is the user applied property I'm searching for
   printf("Found netInfo tag %L \n" car(car(netStruct->net~>allInstTerms~>net~>prop~>name)))
   userFlag=t
   printf("Setting user flag to true \n")
  );when
 );end let
);end proc
  • vtboy51
    **edit* I just realized my userFlag=t and userFlag=nil were flipped, but even with that corrected I don't get the correct behavior. Some nets are hilited that have the user property at a lower level.
  • AurelBuche
    AurelBuche over 2 years ago
    You can try the following snippet, it just add a get_hier_nets function to simplify the use of schTraceNet
    (at the expense of performances, but this should be insignificant):
    (inScheme
      (defun get_hier_nets (cv net)
        "Return all nets connected to NET in CV hierarchy"
        (let (hier_nets)
          (schTraceNet ?topCellView cv ?net net ?traceCB (lambda (hier_net) (push hier_net hier_nets)))
          hier_nets~>net))
    let( ( win cv )
      win = getCurrentWindow()
      cv  = geGetEditCellView(win)
      foreach( net cv->signals
        unless(
          exists( net get_hier_nets(cv net) dbFindProp(net "netInfo"))
          geAddNetProbe( '("y0" "drawing") net->name)
    The inScheme call is important otherwise the function get_hier_nets will not work
    It might not work if the property is not set at net level but on pins
    Cheers,
    Aurélien
  • vtboy51
    vtboy51 over 2 years ago in reply to AurelBuche
    Thanks for this. I have got it to run, but the hilited nets are not quite correct. It is hiliting nets that do the "netInfo" tag at some place in the hiearchy. I'm still investigating, but it seems that the code is only looking at the bottom most schematic for the "netInfo" tag, if the net is tagged at the top level or somewhere in the middle of the hierarchy it's not recognized.
  • vtboy51
    vtboy51 over 2 years ago in reply to vtboy51
    After some more work I have a piece of code that is almost complete for my original question, but the results have triggered a new question regarding the schTraceNet function. Below is the code I have working, but my confusion presents when a net is connected to an iterated instance at a lower level (i.e nand<0:3>).
    Below are some screenshots showing the results when run with both an iterated instance and one with only a single instance. The drawn red arrow is showing where I would expect a line to exist showing the level of hierarchy which contains the iterated instance. The screenshot further below was run after I modified the schematic to only use a single instance, and then you'll see the "missing" line is reported correctly.
    Question is, is this expected behavior? Any feedback would be appreciated.
     defun( findNetInfoCB (netStruct)
       let((inst (inst makeTable("visited" nil)))
      foreach(instTerm netStruct->net~>allInstTerms
       if(car(instTerm~>net~>prop~>name) == "netInfo" then
        printf("A User prop %L found on net %L in hier path %L \n" car(instTerm~>net~>prop~>name) instTerm~>net~>name netStruct->pathToNet)
        userFlag=nil
        printf("Setting user flag to nil for net %L\n" instTerm~>net~>name)
         else
          printf("NO User prop found on net %L in hier path %L \n" instTerm~>net~>name netStruct->pathToNet)
        );if
       );foreach
      );let
    );defun
      printf("\n---------------Net name is %L -----------\n" net~>name)
      userFlag=t
      schTraceNet(?topCellView cv ?net net~>name ?traceCB 'findNetInfoCB)
       if(userFlag then
        printf("\n\nAdding hilite on net %s \n\n" net~>name)
         else
          printf("\n\nNOT hiliting net %s because it already has a user property\n\n" net~>name)
        );if
      );end foreach
    ;;results with iterated instance
    ;;results with NO iterated instance
    Andrew Beckett over 2 years ago in reply to vtboy51
    I did some quick tests and it worked for me - I can imagine it might be something to do with the property being on a bussed net rather than the scalar net, but I'm not sure without an example replicating your setup. Can you contact customer support so that you can work with an application to show your example data? Otherwise I'm having to guess what you've got in your design and where the properties are.
