  3. Schematic PCELL does not update
  • Views 5856
Elisa9
Elisa9 over 2 years ago
Hello, I want to create a schematic pcell, in particular it must instantiate a certain number of component (let's say, switches) and then varying the values of the parameters of these components (for example their vopen, vclose) based on external parameters of the pcell. I don't know what I am doing wrong, but the pcell is stuck at its def values, even if I change the cdf parameters that I defined. I can see cdf parameters when I instantiate the cell but even if I change their values, Vopen and Vclose are still the same in the instance. Here's a simple version of my code, that already doesn't work:
constructor.il
procedure( CCScreatePcell3(cv Von Voff)
let( ()
mstr=dbOpenCellViewByType("analogLib" "switch" "symbol" "schematicSymbol" "r")
switchID=nil
switchID = cons(
inst = dbCreateInst(
cv
mstr
printf( nil "I%d" i)
0:i
"R0"
1
switchID
inst->vt1 = Von
inst->vt2 = Voff
) ;let
) ;procedure
cdf.il
let( ( libId cellId cdfId )
unless( cellId = ddGetObj( "mylib" "myCell3" )
error( "Could not get cell %s." "myCell3")
when( cdfId = cdfGetBaseCellCDF( cellId )
cdfDeleteCDF( cdfId )
cdfId = cdfCreateBaseCellCDF( cellId )
cdfCreateParam( cdfId
?name "Von"
?prompt "Von"
?defValue 1
?type "float"
?name "Voff"
?prompt "Voff"
?defValue 1
?type "float"
cdfSaveCDF( cdfId )
pcell.il
cdf=cdfGetBaseCellCDF(ddGetObj("mylib" "myCell3"))
pcDefinePCell(
list( ddGetObj("mylib") "myCell3" "schematic" "schematic")
list((Von cdf->Von->defValue) (Voff cdf->Voff->defValue))
let( (cv)
cv=pcCellView
schPinListToSymbol("mylib" "myCell3" "symbol" schSchemToPinList("mylib" "myCell3" "schematic"))
) ;let
) ;pcDefinePCell
    There were a few mistakes in the code which would have meant that the code wouldn't produce a schematic PCell at all (because of the commented items I fixed). With this, it works (it's not very useful as the connectivity isn't set up, but the parameter passing is working OK):
    ; constructor.il
      ; variable i was not defined - so set it arbitrarily to 4
      let( ((i 4))
        switchID=nil
        switchID = cons(
            cv
            mstr
            ; this was printf - should have been sprintf
            sprintf( nil "I%d" i)
            0:i
            "R0"
            1
        switchID
        inst->vt1 = Von
        inst->vt2 = Voff
      ) ;let
    ) ;procedure
    ; cdf.il
      ; add some arguments to create the object if the cell doesn't exist
      ; otherwise the CDF won't be created first time around
      unless( cellId = ddGetObj( "mylib" "myCell3" nil nil nil "a" )
        ?name "Von"
        ?prompt "Von"
        ?defValue 1
        ?type "float"
        ?name "Voff"
        ?prompt "Voff"
        ?defValue 1
        ?type "float"
      cdfSaveCDF( cdfId )
    ; pcell.il
    pcDefinePCell(
      let( (cv)
        cv=pcCellView
      ) ;let
    ) ;pcDefinePCell
    ; move to outside of the PCell - you shouldn't have the symbol being created
    ; within the schematic PCell (it would need write access otherwise)
