  3. Change the label of a net
  • Views 6207
GurumurthyH
GurumurthyH over 2 years ago
As you can see in the image there are 3 instances. I want to change the label "A" to "G" of instance x2 without changing the other nets labelled "A"(ie. of instance x1 and x3).
Can anyone help me with a skill code to do so?
    This should do it:
    procedure(CCFchangeConnectedWireLabel(instName wireName newWireName
        @key (cvId geGetEditCellView()))
      letseq(
          (inst dbFindAnyInstByName(cvId instName))
          (master inst~>master)
          pinBox wires
        foreach(term master~>terminals
          foreach(pin term~>pins
            foreach(pinFig pin~>figs
              pinBox=dbTransformBBox(pinFig~>bBox inst~>transform)
              ; only finds wires directly overlapping the pins (so if there
              ; is a bend and then that is labelled, these won't be found)
              wires=dbShapeQuery(cvId list("wire" "drawing") pinBox 0 0)
              foreach(wire wires
                foreach(child wire~>children
                  when(child~>objType=="label" && child~>theLabel==wireName
                    child~>theLabel=newWireName
        t
  • GurumurthyH
    GurumurthyH over 2 years ago in reply to Andrew Beckett
    Thank you, the code is working fine!
