  3. Python <-> Cadence using ipc not reading files
  • Views 4019
Ivangabs
Ivangabs over 2 years ago
Hello, I would like to ask for assistance.
To preface, I have a python code that simply reads a file (open("file.txt")).read()), and outputs the contents to another file.
When I run python using terminal (i.e. python <python_file>), the python code runs correctly.
But when i use ipcBeginProcess, the python code does run, but it does not read and write on the output file.
Anyone can help? Thanks
    It works for me. Which IC version are you using (what does getVersion(t) return in the CIW)? I do see an issue if running (say) python v2 from IC23.1 that if I do:
    id=ipcBeginProcess("myPythonCommand")
    ipcWait(id)
    ipcReadProcess(id)
    I get:
    "Could not find platform independent libraries <prefix>\nCould not find platform dependent libraries <exec_prefix>\nConsider setting $PYTHONHOME to <prefix>[:<exec_prefix>]\n"
    If it's that, you could just run:
    d=ipcBeginProcess("runUserCmd myPythonCommand")
    ipcWait(id)
    ipcReadProcess(id)
    The runUserCmd restores the PATH and LD_LIBRARY_PATH etc back to what it was before Virtuoso started.
  • Ivangabs
    Ivangabs over 2 years ago in reply to Andrew Beckett
    Thank you for the reply.
    I'm using ICADVM20.1-64b
    Python is 2.6.6.
    Also, I was already using ipcWait:
    ipcWait(ipcBeginProcess(strcat("python " x " " y ".temp") "" "" "" "" "CDS.log_py"))
    x is the python script
    y.temp is the input file.
    y.temp_temp is the copied contents from y.temp using python
    For some reason, when I run x in terminal, the y.temp_temp has contents.
    When ran using ipc, y.temp is not being read, and there is no output in y.temp_temp
    Andrew Beckett over 2 years ago in reply to Ivangabs
    I just threw together this simple python script:
    #!/usr/bin/env python
    import argparse
    parser = argparse.ArgumentParser(description='Simple file copier')
    parser.add_argument('inputFile', type=str,
                        help='Input filename')
    args = parser.parse_args()
    data=open(args.inputFile).read()
    newFile=open(args.inputFile+"_temp","w")
    newFile.write(data)
    newFile.close()
    and then this SKILL:
    x="readfile.py"
    y="file"
    and file.temp_temp was created with the same contents as file.temp. Was anything in the CDS.log_py? If an error occurred, you should see it there (I forced an error, such as giving a file that didn't exist, and it reported this there).
  • Ivangabs
    This is my python code:
    import os
    import sys
    s = open(sys.argv[1]).read()
    print("Test Below")
    print(s)
    print(os.getcwd())
    print(sys.argv[1])
    sys.argv[1] should be y.temp. y.temp contents are:
    a 1
    b 2
    c 3
    d 4
    CDS.log_py contents are:
    Test Below
    <working_directory>
    <y.temp>
    Yes, s was not output. Items with <> are censored for privacy reasons, but these values were correct. It's just that s does not have any contents.
    I just tried your code, and it works for me (I'm using ICADVM20.1-64b.500.34 and python 2.7.5 but I'd be surprised if that mattered)
    Test Below
    a 1
    b 2
    c 3
    d 4
    /export/home/myuser/skill
    forum152.temp
