  3. Undefined variables when procedures used in optional ar...
  • Views 6860
Undefined variables when procedures used in optional arguments
theoaoki
theoaoki over 2 years ago
I'm not sure if this is expected behavior or not.
Using the following code, if I set a breakpoint in fun1 on line 2 (right before calling fun2) and step through the program after calling fun1 from the CIW, "var1 does not exist" will print.
If I set var1's default value to 1, "var1 does not exist" will NOT print.
If I don't set a breakpoint, "var1 does not exist" will NOT print.
Any direction would be appreciated!
The code:
procedure(fun1()
fun2()
procedure(fun2(@optional (var1 fun3()))
when(!boundp('var1) printf("var1 does not exist\n"))
procedure(fun3()
1
    This seems to be an obscure bug with the debugger. If you also put a breakpoint on the when line in fun2, and use continue after the first breakpoint - it works. It seems that single-stepping does execute fun3 (but doesn't step through it) but doesn't bind the variable in the argument list - which is a bit strange.
    I'll raise this with R&D (I'll report the CCR number once I've done that).
    Andrew Beckett over 2 years ago in reply to Andrew Beckett
    I filed Cadence Change Request #2977527 for this. It's definitely odd - the optional expression gets evaluated but doesn't get bound to the variable in the argument list.
  • theoaoki
    theoaoki over 2 years ago in reply to Andrew Beckett
    Thanks Andrew!
