  3. fileds not aligned as defined byhoriz_align
  • Subscribers 150
  • Views 6844
kkdesbois
kkdesbois over 2 years ago
I can't understand why the toggle items are not left aligned in their grid column.
with the following code :
(let (familyList l_familiesLayout)
(setq familyList
   (list (list "MOS" (list "TYP" "SLOW" "FAST"))
   (list "BIP" (list "BTYP" "BMIN" "BMAX"))
   (list "RES" (list "RTYP" "RMIN" "RMAX"))
   (list "UNIQ" (list "one")) ))
(foreach family familyList
   (setq l_familiesLayout (cons
      (hiCreateGridLayout (concat "grid_" (car family))
                          ?frame t
                          ?items (list (list (hiCreateLabel ?name (concat "label_" (car family)) ?labelText (car family)) 'row 0 'col 0)
                                       (list (hiCreateToggleField ?name (concat "pdc_" (car family))
        ?choices (foreach mapcar pdc (cadr family) (list (concat pdc))))
                                             'row 0 'col 1 'horiz_align 'left) ))
      l_familiesLayout))
(hiCreateLayoutForm
   'test
   "TEST"
   (hiCreateVerticalBoxLayout 'vbox ?items l_familiesLayout) ?buttonLayout `(OKCancelDefApply)
(hiDisplayForm 'test)
Can someone enlighten me please? I read many posts related to horiz_align but I'm still lost.
Laurent.
    Laurent,
    You have four separate grids. There's no alignment between grid locations between different grids, so this isn't going to work. You could combine as follows:
    (let (familyList familyItems familiesLayout (row -1))
      ; might want to reverse the order of this list?
      (setq familyList
      ; create items for a single grid, with a row for each label
      ; and toggle field. Note that the toggle items won't align perfectly
      ; this way though... but it's simpler
      (setq familyItems
            (foreach mapcan family familyList
                     (postincrement row)
                     (list
                       (list
                         (hiCreateLabel
                         'row row 'col 0)
                       (list
                         'row row 'col 1 'horiz_align 'left)
      (setq familiesLayout
            (hiCreateGridLayout
              'grid
              ?frame t
              ?items familyItems
      (hiCreateLayoutForm
        'test
        "TEST"
          'vbox
          ?items (list familiesLayout (list 'stretch_item 1))
    However, even then there's not going to be alignment between the members of the toggle field. See this:
    I have a second approach which I'll post in a moment.
    Andrew Beckett over 2 years ago in reply to Andrew Beckett
    This approach uses boolean buttons instead of a toggle field. This allows me to place each boolean button in a separate column in a single grid, and hence have everything aligned.
    (let (familyList familyItems familiesLayout (row -1) col)
      (setq familyList
      ; Create items for a single grid, with a boolean button for
      ; every checkbox
      (setq familyItems
                     (postincrement row)
                     (setq col 0)
                     (cons
                     (list
                       (hiCreateLabel
                       'row row 'col (postincrement col)
                              (list
                                (hiCreateBooleanButton
                                  ?name (concat "pdc_" (car family) "_" pdc)
                                  ?buttonText pdc
                                  ?buttonLocation 'left
            (hiCreateGridLayout
              'grid
              ?frame t
              ?items familyItems
      (hiCreateLayoutForm
        'test
        "TEST"
          'vbox
    Here's the output:
  • kkdesbois
    kkdesbois over 2 years ago in reply to Andrew Beckett
    Thanks Andrew for the different replies and suggestions.
    I probably misunderstood (not the first time!) what the option 'horiz_align does. As it is defined at the same time as the grid field (I call grid field a pair row/column), I thought horiz_align was defining how the item placed in that grid field would be aligned.
    I enjoy your usage of foreach mapcan to build the new list! And I'm fond of the functions post/pre increment (and plus, times,...), so much litteral ;)
    Nevertheless I'm attached to the separate grids. Because my next goal is to make visible/unvisible one or several grids according to an external callback that will modifiy the grid(s) argument ?unvisible.
    I'm rebuilding an already existing form created without the hiFormLayout (old method with coordonates/spacer/width for each field). In this already existing form, it's complicated to make unvisible some fields unless recreating the form
    Each grid will have (in my example) two columns. I can fix the minimum width of the 1st colum, and ensure it will be the same width for all the grids. And the width of the second column will depend on how many toggles are in it.
    But It doesn't matter as long as the toggle is left aligned in its grid field
    It's not a problem if the toggles are not vertically aligned because some families may have corner names longer than 4 characters
    I'm going to try different vbox/hbox combinations and see if it can be more flexible than grids.
    Laurent.
    Andrew Beckett over 2 years ago in reply to kkdesbois
    Laurent,
    You could of course just set the visibility on all the items in a row. For example:
    (defun CCFsetRowVisibility (form row invisible)
      (foreach rowField
               (setof field form->fieldList
                      (equal
                        (cadr (hiGetGridLayoutItemLocation form field))
                        row))
               (putpropq (get form rowField) invisible invisible))
      t
    Then use:
    (CCFsetRowVisibility test 1 t) ; or nil if you want to make visible again
  • kkdesbois
    I note it.
    In the real code, each grid is composed of several rows that will have to (dis)appear.
    But by using your previous code suggestion, I should be able to make invisible every items of several rows.
    You make a row invisible by using its number. i need to access to the fields in the row thanks to the family name.
    Let me digest all the informations and see how to use them in my project.
    Thanks again.
    You could either use the family name part of the field name to do the filtering, or you could store an explicit property on each field to say which family it belongs to - that would allow a similar approach - it's just a matter of identifying the relevant fields somehow.
    Anyway, hopefully you now have a few ideas of approaches that you might consider!
