  3. Text Window Information Extraction
  • Subscribers 153
  • Views 5888
Ivangabs
Ivangabs over 2 years ago
Good day!
I would like to ask if there are any ways to extract the text inside this kind of window? I have covered some parts of the window for privacy reasons, but basically this window contains the log file after an execution. I would like to extract the information directly from this window, and not from the logfile itself.
Thank you for your time.
    procedure(CCFreadTextFromWindow(@optional (winId hiGetCurrentWindow()))
      let(((len hiGetTextSourceLength(winId)))
        hiSetCurrentTextSelectionLoc(winId 0 len-1)
        prog1(
          hiGetCurrentTextSelection(winId)
          hiClearCurrentTextSelection(winId)
    Then just call: CCFreadTextFromWindow() - which will get the text from the current window, or CCFreadTextFromWindow(windowId) ; e.g. window(5) in your example. There are other functions that could be used such as getting the data one character at a time using hiGetTextCharAtLoc but I think getting the selection is simpler.
  • Ivangabs
    Ivangabs over 2 years ago in reply to Andrew Beckett
    Thanks Andrew, it works. Exactly what I needed.
