  3. How to add frames in schematic view by help of skill language...
  • Views 5554
How to add frames in schematic view by help of skill language ?
aryansingh
aryansingh over 2 years ago
Hi everyone,
I am writing a skill script to add frames in schematic view by the help of skill language and I am able to generate that frame as per need, but Now I need help in Saving that frame over schematic area (which include all devices in it) So is there any function available for same or what approach should I go for to save that frame?
Thanks & regards
Aryan
    If by "frame" you mean a sheet (such as via the Edit→Sheet Size menu), then it's just an instance of that symbol (dbCreateInst would create it). Then it's part of the schematic and would get saved with it. It's not really clear what you're asking...
