  3. Re: evaluating of variables in netlist created by maeCr...
  • Views 5368
Re: evaluating of variables in netlist created by maeCreateNetlistForCorner
slim15
slim15 over 2 years ago
When using maeCreateNetlistForCorner to create netlist, I noticed that the input.scs created by the command line has difference compare to the ones created by GUI in Explorer/Maestro. For example, via GUI  the top part of the input.scs from the two methods are shown below
// GUI
simulator lang=spectre
global 0
parameters VDD=900m freq1=1.0G freq2=1.1G SIM_END=10.0/(freq2-freq1)
// command line
global 0
parameters VDD=0.9 freq1=1.0000000000000000e+9 1.1000000000000000e+9 freq2=1.10000e+9 SIM_END="10.0/(freq2-freq1)"
Is there a flag that should be set before executing the maeCreateNetlistForCorner command to make the input.scs generated by the command line to be the same as that generated by GUI?
Regards
slim
    Which IC sub-version are you using? Is the netlist from the "GUI" created by virtue of running the simulation, or are you doing it from the Run Preview tab (otherwise how are you creating the netlist for a specific corner)? I assume the issue is not really the numbers but the SIM_END being a string (that looks wrong, and looks like a bug to me). I don't see otherwise why it would matter whether 1.100000e+9 is used instead of 1.1G.
