  3. Skill code to copy object to another metal layer but maintain...
  • Views 7068
Skill code to copy object to another metal layer but maintain the objects purpose
cvictoria
cvictoria over 2 years ago
Hi so I'm trying to convert my selected object into another metal layer put want to maintain the purpose. For example, if i have M1 exclude I want to convert it to M2 exclude. or an M1 drawing to a M2 drawing etc.
The code I've written works if I always want to be converting to drawing, but I can't seem to figure out how I can maintain the purpose. I don't want to only be converting it to type "drawing" and placing my objPurpose variable instead of "drawing" gives me errors.
procedure(CopytoLayer(objT)
obj = geGetSelSet()
objPurpose= cadr(car(obj~>lpp))
printf("The objects purpose is %s \n" objPurpose)
case(objT
(objT == "M1"
obj~>lpp = ("M1" "drawing"))
(objT == "M2"
obj~>lpp = '("M2" "drawing"))
(objT == "M3"
obj~>lpp = '("M3" "drawing"))
I understand I could make more cases where I can assign according to the result of my objPurpose variable, but this seems tedious to do for M1 exclude, M1 drawing, M1 vdd etc. So I'm sure theres a better way but I'm not seeing it.
Any help would be appreciated.
  • AurelBuche
    AurelBuche over 2 years ago
    Hi, There you go:
    procedure(CopytoLayer(layerName)
      obj = car(geGetSelSet())
      destructuringBind( (_layer purpose) obj->lpp
        printf("The objects purpose is %s \n" purpose)
          if( leIsLayerValid( list( layerName purpose ))
            then
            obj->lpp = list( layerName purpose )
            else
            obj->lpp = list( layerName "drawing" )
    Cheers,
    Aurélien
  • skillUser
    skillUser over 2 years ago
    Here's something you can try - using the 'Active Layer' (i.e. the one selected in the Layers Palette) as the metal to change TO, select one or more shapes and run the code below:
    procedure(CCFchangeToActiveLayKeepPurpose(@optional (objs geGetSelectedSet()) "l")
      let((activeLpp)
        activeLpp = leGetEntryLayer()
        objs~>layerName = car(activeLpp)
    You can put 'CCFchangeToActiveLayKeepPurpose()' on a bindkey so you'd just need to select the metal (or other layer to change to), select your shape or shapes, and then press the bindkey - it keeps the current purpose but changes the layer to the one that is active in the Layers Palette. This function does not attempt to check if the new lpp combination would be valid, so if the current shapes' purpose does not exist for the new layer it would fail (or worse, it would do the action but then you might not be able to select the shape again as it is not on a valid LPP, so be warned).
    Best regards,
    Lawrence.
