  3. to check spacing between the CPO layer in each Poly lay...
  • Views 6628
to check spacing between the CPO layer in each Poly layer
Shivangi Chauhan
Shivangi Chauhan over 2 years ago
Hi ,
I want to check the spacing between the cpo layer in each poly in 16nm and when I am using dbGetNeighbour command it is taking the other poly's CPO if it is closest to that  cpo. can anyone help me with the skill command or code for the same.I have attached the image for the same.
Thank you
  • RobMan
    RobMan over 2 years ago
    'dbGetNeighbor' returns a list containing information about the closest neighboring shape in the specified direction of the given layer-purpose pair. Shapes that overlap the searching box are ignored. The related (to CPO) poly will overlap (by definition of it's function). There is no true CPO-Poly spacing in this context. It's not clear what you are trying to achieve.
  • Shivangi Chauhan
    Shivangi Chauhan over 2 years ago in reply to RobMan
    I want to write a script if poly is routing more than specific height then it will flag error in 16nm  as the poly is continuous in 16nm tech , So for that I am taking reference of CPO layer if the spacing between the CPO layer is more than the specified value we can say poly is routing greater than specified value for each poly.
  • RobMan
    RobMan over 2 years ago in reply to Shivangi Chauhan
    You might be better analysing the poly shapes. Use...
      leLayerAndNot(cv list("poly" drawing") list("CPO" "drawing") list("y0! "drawing")
    and...
      leSizeShape( shape '(0 0 shrinkVal shrinkVal))
    N.B. The shrinkVal will be 0.5 x maxLength.
    There is obviously more to it than that. And not sure what you expect to manage hierarchical shapes. It's likely to get complicated. Probably best to create a Pegasus (or PVS) DRC rule.
  • Shivangi Chauhan
    okay, Thank you for this reply!!
