  3. leHiStitchToLayer - two vias instead of one?
  • Views 1326
caver456
caver456 over 2 years ago
Is there a way to draw two cuts instead of one when using leHiStitchToLayer, or a similar command, during interactive wire editing?
  • RobMan
    RobMan over 2 years ago
    If you set 'Min Num Cuts' in the Wire Assistant or  envSetVal("layout" "viaMinNumCuts" 'int 2).
    Alternatively define a Constraint Group to apply double cut vias.
  • caver456
    caver456 over 2 years ago in reply to RobMan
    Works like a charm, thanks!
