  3. SKILL code to create a GUI
  • Views 8027
AB_1716450780384
AB_1716450780384 over 2 years ago
Hi all,
I am new to SKILL  and I am trying to create a GUI . I tried to write a code a below but for reason though I am not getting any error  but GUI is not created.
Can someone help me correct this code.
procedure( testGUI()
        hiCreateAppForm(
                       ?name 'myGUI
                       ?formTitle "testGUI"
                       ?fields list(
                                        list( hiCreateButton(
        ?name 'M1p
        ?buttonText "+M1" ) 0:5 70:20 )
       hiDisplayForm( testGUI )
);end procedure
Shweta
    Shweta,
    It should give:
    *Error* eval: unbound variable - testGUI
    perhaps you have errors turned off in the Options->Log Filter in the CIW?
    The issue is the hiDisplayForm line - it should be hiDisplayForm(myGUI) (not testGUI)
  • AurelBuche
    AurelBuche over 2 years ago
    Also, you should try creating your gui with hiCreateLayoutForm instead of hiCreateAppForm
    Those functions are way simpler to create nice interfaces.
    You don't need to calculate the coordinates of your items, nstead you create vertical and horizontal layouts using
    hiCreateFormLayout, hiCreateVerticalBoxLayout or hiCreateHorizontalBoxLayout
    Here's an example :
      hiCreateLayoutForm( 'myGUI "testGUI"
        hiCreateFormLayout( 'main_layout
          ?items list(
            hiCreateButton(
              ?name 'M1p
              ?buttonText "+M1"
              ?callback lambda( (_button _form)
                         ;; This code is executed when button is clicked
                         (info "+M1 button clicked\n")
    hiDisplayForm( testGUI())
    Cheers,
    Aurélien
  • AB_1716450780384
    AB_1716450780384 over 2 years ago in reply to Andrew Beckett
    Thanks for pointing out . It helps.
  • AB_1716450780384
    AB_1716450780384 over 2 years ago in reply to AurelBuche
    Thanks Aurélien , it works. I used  hiCreateVerticalBoxLayout / hiCreateHorizontalBoxLayout for futher code. Slight smile
