  3. unexpected sort behavior
  • Views 5612
amac
amac over 2 years ago
Hello, have you ever experienced a sort function that "eats" part of a list?
m=list(list("a" "MM") list("p" "PP" ))
sort(m lambda((a b) alphalessp(cadr(b) cadr(a))))
If executed from CIW it correctly produces:
m
(("a" "MM")
    ("p" "PP")
If executed within a .il file it gives:
m
(("a" "MM"))
What is happening?
  • AurelBuche
    AurelBuche over 2 years ago
    sort is a destructive function.
    It actually modifies the pointers inside your list, you should always be careful while using it :
    It's OK, if you sort a list that is generated on the fly
    (sort (geGetEditCellView)->instances (lambda (i0 i1) (alphalessp i0->name i1->name))))
    Otherwise, you have two solutions :
    1. Re-assign the sorted list :
    m = list(list("a" "MM") list("p" "PP" ))
    m = sort(m lambda((a b) alphalessp(cadr(b) cadr(a))))
    2. Copy the list before sort :
    sort(copy(m) lambda((a b) alphalessp(cadr(b) cadr(a))))
    Cheers
    Aurélien
  • amac
    amac over 2 years ago in reply to AurelBuche
    Indeed assigning the result to m itself solves the issue.
    Thanks a lot!
