  3. Execute only the procedure of a program
  • Views 6429
Mabr86
Mabr86 over 2 years ago
Is it possible to only execute a specific procedure of a sub-program when opening this sub-program from the main program?
  • AurelBuche
    AurelBuche over 2 years ago in reply to Mabr86 +1
    Then no, there is no trivial way to just define the `greet' procedure. That is why it is advised to write SKILL files that only define procedures (except for what you call the "main" program) So they…
  • AurelBuche
    Your question is so vague... are you even talking about SKILL?
    An example of what you have and what you want to achieve would be welcome.
    Let's assume what you call the main program is Virtuoso and that you want to call a specific SKILL function.
    If you have a file like ~/skill/example.il which contains :
    (defun example_procedure ()
      (info "calling `example_procedure'")
    Then yes, you can load this file in Virtuoso and then call `example_procedure'.
    CIW> (load (simplifyFilename "~/skill/example.il"))
    -> t
    CIW> (example_procedure)
    -> nil
    If your file is not defining functions but running code directly, this can be very dangerous, as shown in the following example :
    The file ~/skill/example.il could contain
    (deleteFile ...)
    And when loading them you might erase files.
  • Mabr86
    Mabr86 over 2 years ago in reply to AurelBuche
    For example...
    Content of the sub-program:
    printf("test")
    procedure(greet()
    printf("Happy Birthday")
    );end procedure
    Now, in the main program I want to call the sub program above. But just the procedure "greet()" should be executed, not the "printf(test")".
  • AurelBuche
    So they can be loaded and their procedures can be called individually
    In your case, you could write a function that parses the SKILL expressions inside a given file (usually this is done using `lineread') and only evaluate the S-expressions starting with `defun' or `procedure' but I would advise you not to do so as this is very unusual.
  • Mabr86
    Ok, thank you for your quick response.
