  3. hiCreateComboField() ?callback func
  • Subscribers 150
  • Views 7720
Yush
Yush over 2 years ago
hi,
I want to create three Combo fields to select lib, cell and view. Proactively identify whether the current cellName exists in the selected lib, and assign the first cellName of the selected lib if not exist.
But there was error when click OK Cancel Apply :Error in routine ilGetString:
Message: *Error* ilGetString: arg must be symbol or string. Entering new debug top level due to error:
I have no idea why trigger fields callback when click ok cancel apply?
procedure(testSelectCV()
let((lib cell view)
    lib = hiCreateComboField(
        ?name 'lib
        ?prompt "lib"
        ?items ddGetLibList()~>name
        ?callback "testSelectCV_SelCB(hiGetCurrentForm() \"lib\")"
    cell = hiCreateComboField(
        ?name 'cell
        ?prompt "cell"
        ?callback "testSelectCV_SelCB(hiGetCurrentForm() \"cell\")"
    view = hiCreateComboField(
        ?name 'view
        ?prompt "view"
        ?callback ""
    testSelectForm = hiCreateAppForm(
        ?name 'testSelectForm
        ?formTitle "testSelectForm"
        ?fields list(
            list(lib 10:10 200:30 60)
            list(cell 10:50 200:30 60)
            list(view 10:90 200:30 60)
        );end fields
    ?callback "");end create app form
    hiDisplayForm('testSelectForm)
    t);end let
);end proc
procedure(testSelectCV_SelCB(form \@optional field("lib"))
let((cells currentCell views currentView)
    cond(
        (field == "lib"                ;;Control cell field
            currentCell = form->cell->value
            when(artBlankString(currentCell)
                cells = ddGetObj(form->lib->value)->cells~>name
                form->cell->items = cells
                form->cell->value = car(cells)
            );end when
            unless(artBlankString(currentCell)
                unless(member(currentCell cells)
                );end unless
            );end unless
        (field == "cell"        ;;Control view field
            currentView = form->view->value
            when(artBlankString(currentView)
                views = ddGetObj(form->lib->value form->cell->value)->views~>name
                form->view->items = views
                form->view->value = car(views)
            );end when
            unless(artBlankString(currentView)
                unless(member(currentView views)
                );end unless
            );end unless
    );end cond
    t
    );end let
);end proc
  • mbracht
    mbracht over 2 years ago +1
    Hi, I don't get this error. Apply doesn't do anything at all and both Ok as well as Cancel close the form...which is the expected behavior. And since you don't have any callbacks defined, what is that…
    Andrew Beckett over 2 years ago in reply to mbracht +1
    Also, it would be easier to use the ddHiCreate*ComboField functions which make all this a lot easier as they do the work for you. See my example code in this post (note there's a link to another post which…
  • Yush
    Yush over 2 years ago in reply to mbracht +1
    Thanks for reply, mbracht and Andrew, My virtuoso version is 616, and ddHiCreate*ComboField functions can not be used in that version. Other blogger guess, click cancel after selecting libName, fields…
  • mbracht
    I don't get this error. Apply doesn't do anything at all and both Ok as well as Cancel close the form...which is the expected behavior. And since you don't have any callbacks defined, what is that GUI supposed to do...I mean other than displaying the first cell and view of a selected library?
    Max
    Also, it would be easier to use the ddHiCreate*ComboField functions which make all this a lot easier as they do the work for you. See my example code in this post (note there's a link to another post which gives a newer and expanded version of the example code too).
  • Yush
    My virtuoso version is 616, and ddHiCreate*ComboField functions can not be used in that version. Other blogger guess, click cancel after selecting libName, fields callback func was triggered, so the value of fields changed but not saved in form. When click cancel form is unmaped, the results is same as hiFormCancel done, fields callback were triggered, the return of hiGetCurrentForm is nil at this time,  error ocurred in callback function routine.
    And I change hiGetCurrentForm to r_form, the problem solved.
    hiGetCurrentForm() => nil ; form->lib->value or form->cell->value => error!
    Yush
  • AurelBuche
    AurelBuche over 2 years ago in reply to Yush
    I made a trial and the error actually occurs twice when you close (or cancel) the form
    (It doesn't raise an error with OK, or Apply)
    So the callback being triggered by leaving the edited fields makes sense (even though I'm surprised)
    Anyway, the error itself is actually coming when one of the following line returns nil.
    You can fix the error using a simpler coding style and doing the appropriate checks.
    You have weird statements:
      - You are using both `when' and `unless' when most people would use `if' or `cond'
      - You are using `cond' when `case' is more suitable
    Here is the updated code :
    procedure(testSelectCV_SelCB(form @optional field("lib"))
        case( field
            ("lib"                ;;Control cell field
                ;; Fetch library cells
                unless( artBlankString(form->lib->value)
                ;; Change cell only if :
                ;; - cells where found
                ;; - current cell is not among them
                when( cells
                    form->cell->items = cells unless( member(currentCell cells) form->cell->value = car(cells) ) ) ) ("cell" ;;Control view field currentView = form->view->value ;; Fetch cell views unless( artBlankString(form->lib->value) && artBlankString(form->cell->value) views = ddGetObj(form->lib->value form->cell->value)->views~>name ) ;; Change view only if : ;; - views were found ;; - current view is not among them when( views
    form->view->items = views unless(member(currentView views) form->view->value = car(views) ) ) ) );end cond t );end let );end proc
  • Yush
    Yush over 2 years ago in reply to AurelBuche
    Thanks for help, AurelBuche,
    The updated code sovled the error, but there maybe missing the code of assign value to cell/view field's items:
    the views case also missing
    Yush
  • AurelBuche
    You are right, I updated the code of my previous answer
