  3. Skill code to generate selected devices from schematic to...
  • Replies 7
  • Subscribers 150
  • Views 11645
Skill code to generate selected devices from schematic to layout view
skillLover
skillLover over 2 years ago
Hi everyone,
I am looking for some guidance regarding a skill script that i am working on.
Basically, i want to generate devices from schematic to layout.
Virtuoso Layout XL has already this feature called "generate from source ( pick n place)" but i am trying to replicate this feature to Layout L, layout L does not have this feature.
I tried different approaches, i am listing one by one:
1. First of all, i fetched the db id of the selected device in schematic
pmosCV = geGetSelSet()
pmosCV = (car pmosCV)
2. Next i got the db id of the layout view
layCV = geGetEditCellView()
3. Then i went with the following approach to copy the device to layout and store the id
copiedFig = dbCopyFig(pmosCV layCV)
Now, i am facing the main issue,
if i try to change the viewName from symbol to layout, its not letting me change.
copiedFig~>viewName = "layout"
its throwing error
if i try to use dbreplaceprop, its creating a new property rather than changing the viewName attribute.
i tried some other apis all out of luck.
interestingly, i can change symbol to layout manually, using the Q key to manually enter the property tab of the symbol in layout view, and change viewname from symbol to layout then save, it works.
so, the bind key Q is tied to "leHiEditProp()" command but its manually done.
basically, i want this manual process to get automated using skill, any clue, hints or guidance would be appreciated..
thank you
  • RobMan
    RobMan over 2 years ago +1
    Re. copiedFig~>viewName = "layout" its throwing error Why not tell us what the error is? It's a big effort to achieve XL like functionality. There is no 'L' in Virtuoso Studio you should consider upgrading…
    Andrew Beckett over 2 years ago in reply to RobMan +1
    I agree entirely with Rob. The issue you're facing is that you can't remaster an instance by changing the viewName. You could change ~>master to the db object of the layout cellView, but there's a whole…
  • RobMan
    It's a big effort to achieve XL like functionality. There is no 'L' in Virtuoso Studio you should consider upgrading.
    If you must DIY then I suggest building some mapping table and place the instances from scratch. Copying the schematic symbol is not a good approach.
    The issue you're facing is that you can't remaster an instance by changing the viewName. You could change ~>master to the db object of the layout cellView, but there's a whole lot of things that you'd need to deal with, such as m-factor, iterated instances and many others which your simplistic approach won't handle.
  • skillLover
    skillLover over 2 years ago in reply to RobMan
    pardon me for my oversight,  i have attached my inputs with corresponding output below:
    copiedFig~>viewName
    "symbol"
    *Error* setSGq: (DB-370034): dbSetq: Cannot set attribute - viewName
  • skillLover
    skillLover over 2 years ago in reply to Andrew Beckett
    I  understand, i thought maybe something can be worked out, because the symbol which is copied by the dbcopyfig command to the layout, has all the necessary values , changing just viewname manually to layout works out.
  • skillLover
    Currently, i am using Virtuoso IC6.1.7 which is quite old but this is currently what i have in my arsenal at the moment.
  • skillLover
    Upon some further debugging, i found that lxHiCreateInstFromSch() in layout xl is responsible for generating the device from sch, but in layout L mode, it seems to not work.
  • RobMan
    RobMan over 2 years ago in reply to skillLover
    Yes, because that is part of LayoutXL functionality. Not L.
