  3. Need assistance on changing the ViewtoUse of config vie...
  • Views 6030
Need assistance on changing the ViewtoUse of config view
SHRYS
SHRYS over 2 years ago
Hi All,
I am able to create the config view using the script shared by Sir Andrew below:
procedure(CCFcreateConfigView(lib cell view topView @key
(viewList "spectre cmos_sch cmos.sch schematic veriloga ahdl symbol")
(stopList "spectre symbol")
(libList "test template_tb analogLib")
let((hdb)
hdb=hdbOpen(lib cell view "w")
unless(hdb error("Could not open %s/%s/%s for write\n" lib cell view))
hdbSetTopCellViewName(hdb lib cell topView)
when(stringp(libList)
hdbSetDefaultLibListString(hdb libList)
when(stringp(viewList)
hdbSetDefaultViewListString(hdb viewList)
when(stringp(stopList)
hdbSetDefaultStopListString(hdb stopList)
hdbSave(hdb)
hdbClose(hdb)
t
But I need to change the ViewtoUse from schematic view to symbol view, as we do in configuration GUI. I tried using hdbcBindingRule, but it is not supported in the cadenceICADVM/20.10.330. I am unable to use the command hdbExplainBinding too.
Can somebody help me out with this.
Thank you so much & in Regards,
Shreyas K
    This is certainly possible in this version - it has been available for many, many years. I suspect you're trying to call a function incorrectly. It would be something like:
    hdbSetObjBindRule(hdb list(list("opamp090" "ampp" nil nil))
      list('hdbcBindingRule list(nil nil "myschemview"))
    This is setting the view to use to be "myschemview" on the cell opamp090/ampp. I just tested this, and it works fine. The documentation shows examples of other kinds of bindings you can do.
  • SHRYS
    SHRYS over 2 years ago in reply to Andrew Beckett
    Thanks Andrew... I am able to call it with this above syntax... & it is working as expected.
    Thank you so much again
