  3. How to utilize the dbIDs I got from dbGetTrueOverlaps
  • Replies 7
  • Subscribers 150
  • Views 7929
dakuang01
dakuang01 over 2 years ago
I always find this most difficult for me to utilize the data list I got from dbGetTrueOverlaps.
I got a function from here to be able to utilize the targeted info. I think it was dbGetOverlapShape(overlap) or something.
But what I'm trying to do now is to remove some lists having their cellnames as "abcde_*", which I need to use the dbID of the first list of the concatnated lists instead of the last list.
d_tmp = dbGetTrueOverlaps(cv l_bBox_4xMT "M1_4B" 20 t)
In other words, I got a concatnated list from the overlap function above. And I would like to remove the lists of the cells "abcde_*".
Hope this makes sense and I could get some great help like I used to do.
dakuang01
  • dakuang01
    dakuang01 over 2 years ago in reply to Andrew Beckett +1
    I'm currently testing on a case with a simple hierarchy and I attached an image for an example. The fisrt db:0x6b6c6120 is an instance(could be a mosaic too) data having the cellname information that I…
    Andrew Beckett over 2 years ago in reply to dakuang01 +1
    The documentation does explain how the output is structured. I suggest you look there. It's in effect giving the hierarchical path down to the leaf object found by dbGetTrueOverlaps. The picture doesn…
  • dakuang01
    I realized by knowing the depth of the lists I got from the overlap function, this issue might be handled and I found a function abListDepth Andrew provided.
    Any other extra help on this issue would be much appreciated too!
    It's not that clear what exactly you're trying to filter out here - where this cellName "abcde_*" is in the data you are needing to filter. So without that, hard to know what you really want (or don't want, in this case!)
  • dakuang01
    The fisrt db:0x6b6c6120 is an instance(could be a mosaic too) data having the cellname information that I need to filter.
    And the second db:0x4dd694ac is stdVia that includes M1_4B and the last one db:0x3a7bb49e is rect that I targeted M1_4B.
    I think I need a better understanding of the hierarchy of the data from the overlap function. On a complex hierarchy, I might not solve this issue.
    The picture doesn't help me much, I'm afraid...
  • dakuang01
    Ok I'll look into it. When I have more specific questions, I'll ask again. Thanks for your reply!!
  • dakuang01
    I've been trying a few methods to approach the cells with the cellname "abcde_*" but I ran into issues.
    Basically, the question you asked is the very issue I'm having. Depending on the hierarchy of the layout, I don't know how to figure out where the cells are in the data.
    The only thing I know is the leaf object and the cell I'm looking for are the elements of the very bottom of the concatenated list in hierarchy-wise like the image I attached before. They're in the same level.
    Or do I need to check every single element whether each element is "inst" or "mosaic" with the cellname I'm searching?
    I might need to use a recursive function. And I'm not very familiar with it.
    Any advice? Please help me!
    dakuang01
    You seem to have asked the same question again in this thread (with a little more detail), so closing this one off and continuing it in that thread.
