  3. rexMatchp
  • Subscribers 150
  • Views 7781
rexMatchp
dakuang01
dakuang01 over 2 years ago
Hello!
I think I need a clearer understanding on the function rexMatchp.
I'm trying to get a list not having cells starting the name with "mesh2_20x20" so I'm using the function.
Here's some of the experiments of it.
I wasn't expecting the two cases in pink would give me t. I was expecting nil. Am I missing anything here or any advice please?
rexMatchp("mesh2_20x20*" "mesh2_20x20")
t
rexMatchp("mesh2_20x20*" "mesh2_20x20_OL")
t
rexMatchp("mesh2_20x20*" "mesh2_20x21")
t
rexMatchp("mesh2_20x20*" "mesh2_20")
nil
rexMatchp("mesh2_20x20*" "mesh2_20x2")
t
dakuang01
    Andrew Beckett over 2 years ago in reply to dakuang01 +1
    First of all, I would advise against using rexMatchp unless you really need to have code that works in IC5141. The PCRE functions (e.g. pcreMatchp, pcreCompile, pcreExecute etc) support a much richer regular…
    Yes, ^ at the beginning means the beginning of the string. $ at the end means to match the end. If you look at the documentation for rexCompile, it explains the meaning of the magic characters. For PCRE…
  • dakuang01
    Oh I just found out it worked good by using both rexCompile and rexExecute!
    First of all, I would advise against using rexMatchp unless you really need to have code that works in IC5141. The PCRE functions (e.g. pcreMatchp, pcreCompile, pcreExecute etc) support a much richer regular expression syntax than the POSIX rex functions.
    The issue with your results (and I don't see why rexCompile/rexExecute would behave differently - they don't in my experiments) is that the end of your expressions are "0*" This does not mean 0 followed by anything, it means any number (including zero) of the character 0. So it matches "", "0", "00", "00000" etc. The regular expressions are not anchored, so they will match starting anywhere and ending anywhere - so characters which follow the matching part are irrelevant in the success. Perhaps you wanted: "^mesh2_20x20.*" or even just "^mesh2_20x20" - omitting the final *
  • dakuang01
    dakuang01 over 2 years ago in reply to Andrew Beckett
    Yes my bad. I also noticed that omitting the final * worked for both rexMatchp and rexCompile/rexExecute.
    Can I take that "^" in front function as a starting point?
    I tried to search what each meta-character does but unfortunately couldn't find.
    Yes, ^ at the beginning means the beginning of the string. $ at the end means to match the end. If you look at the documentation for rexCompile, it explains the meaning of the magic characters. For PCRE though you can just use "man perlre" to see the regular expression syntax (there are lots of resources on the web covering this, including https://en.wikipedia.org/wiki/Regular_expression - for the "rex" functions see the "BRE" part of the POSIX section; for PCRE there's a PCRE section).
  • dakuang01
    Thank you Andrew for your great help. You're amazing.
