  3. I am facing the following error: get/getq: first arg must...
  • Subscribers 147
  • Views 1616
I am facing the following error: get/getq: first arg must be either symbol, list, defstruct or user type - 0.0
AB_1718192359764
AB_1718192359764 over 1 year ago
I am trying to define a function to check all pins are on border and mark incorrectly set pins. But I get the following error: *Error* get/getq: first arg must be either symbol, list, defstruct or user type - 0.0
Can you please help me with this.
Ananth.
procedure(CCSfindPinsOnBorder()
let((cv allPins count incorrectPins layoutBoundary)
cv = geGetWindowCellView()
if(cv then
allPins = setof(x cv~>shapes x~>pin)
count = 0
incorrectPins = 0
layoutBoundary = cv~>bBox
foreach(pin allPins
let((pinBoundary llx lly urx ury)
pinBoundary = pin~>bBox
when(pinBoundary
llx = pinBoundary~>llx
lly = pinBoundary~>lly
urx = pinBoundary~>urx
ury = pinBoundary~>ury
if(not(
(llx == layoutBoundary~>llx) ||
(lly == layoutBoundary~>lly) ||
(urx == layoutBoundary~>urx) ||
(ury == layoutBoundary~>ury)
) ;not
then
geSelectFig(pin)
incorrectPins++
printf("Incorrectly placed pin with net %s found at %L\n"
pin~>net~>name centerBox(pinBoundary))
) ;if
) ;when
count++
) ;let
) ;foreach
printf("%d pin(s) checked in cell %s\n"
count cv~>cellName)
printf("%d incorrectly placed pin(s) highlighted\n"
incorrectPins)
) ;if
) ;let
) ;procedure
    You can't use pinBoundary~>llx (I've no idea why you thought you could - strangely enough there was another post recently which did the same thing here). A bounding box is a list of two lists, each of which is a number. So none of the ~>llx, lly, urx, ury will work on these (similarly in your previous, now deleted, post where you were trying to index lists using array syntax - lists are not arrays).
    I rewrote this slightly to use destructuringBind to pull out the llx, lly etc, plus to optionally use the prBoundary if present (worked better in my case). I also indented it (debugging unindented code is rather hard)
      let((cv allPins count incorrectPins layoutBoundary pinBoundary)
        if(cv then
          count = 0
          incorrectPins = 0
          ; use prBoundary (assume rectangle here for simplicity) or use
          ; cellView bBox if not found. Note that the bBox may not be
          ; correct if you have labels protuding outside of the shapes
          layoutBoundary = cv~>prBoundary~>bBox || cv~>bBox
          destructuringBind(((lbLLX lbLLY) (lbURX lbURY)) layoutBoundary
            foreach(pin allPins
              ; shapes always have a bBox, so no need to check
              destructuringBind(((llx lly) (urx ury)) pinBoundary
                if(not(
                  (llx == lbLLX) ||
                  (lly == lbLLY) ||
                  (urx == lbURX) ||
                  (ury == lbURY)
                  ) ;not
                then
                  geSelectFig(pin)
                  incorrectPins++
                ) ;if
                count++
              ) ;destructuringBind
            ) ;foreach
          count cv~>cellName)
          incorrectPins)
        ) ;if
      ) ;let
    ) ;procedure
  • AB_1718192359764
    AB_1718192359764 over 1 year ago in reply to Andrew Beckett
    Thank you, Andrew! I will correct my mistakes as I am quite new to scripting.
