  3. Align rod rectangle created with elementsX and elementsY...
  • Views 5790
MorrisDH
MorrisDH over 2 years ago
My code: Using gpdk045
How to align multi-element rects?
load "./mySkill/alignProc.il"
procedure( alignProc(@key (cvId geGetEditCellView()))
let( (defaultSize cuFrame alEnc alFrame)
defaultSize = 2
alEnc = 3*defaultSize
cuFrame = rodCreateRect(?cvId cvId ?layer "M1Resdum" ?width defaultSize ?length defaultSize
?elementsX 3 ?elementsY 7 ?spaceX 0)
alFrame = rodCreateRect(?cvId cvId ?layer "M2Resdum" ?width alEnc ?length alEnc
?elementsY 3 ?spaceX 0)
rodAlign(?alignObj alFrame ?alignHandle "lowerLeft"
?refObj cuFrame ?refHandle "upperLeft")
) ; let
) ; procedure
The rodAlign command returns ROD-1032 warnings and the alignment fails. Is there a way to align 'cuFrame' to 'alFrame' as defined above.
There are other ways to accomplish the above but there existing code using elementsX and elementsY so if it can be made to work it would be great.
Cheers to all,
    The issue here is that rodCreateRect (in this case) is returning a list of the individual rod objects because of your use of ?elementsX and ?elementsY. You can't align a list of ROD objects to another list. Aligning just one of them in each list won't work either, since there's no alignment between the individual objects.
    I added this function to your code which sets up alignments between the objects returned by rodCreateRect (note the comments) and then aligns one of them from each set. This then gives you a persistent alignment between all of the objects.
    ; Given the return value of rodCreateRect when it is returning
    ; a list of rodObjects, use the documented order (starting at
    ; upperRight, top to bottom then right to left, ending at
    ; lowerLeft) to set up alignments between the rectangles.
    ; note that this is assuming 0 spacing between the objects. That
    ; would need adjusting if that's not the case.
    procedure(alignRodRects(rodRects @key (elementsY 1))
      letseq(((prevRect car(rodRects)) (prevCol prevRect) (index 1))
        foreach(rodRect cdr(rodRects)
          if(mod(index elementsY)==0 then
            rodAlign(
              ?alignObj rodRect ?alignHandle "upperRight"
              ?refObj prevCol ?refHandle "upperLeft"
            prevCol=rodRect
          else
            rodAlign(
              ?alignObj rodRect ?alignHandle "upperLeft"
              ?refObj prevRect ?refHandle "lowerLeft"
          prevRect=rodRect
          index++
        t
        defaultSize = 2
        ; add alignments between the objects in each list
        alignRodRects(cuFrame ?elementsY 7)
        alignRodRects(alFrame ?elementsY 3)
        ; align the lowermost alFrame to the uppermost cuFrame
        rodAlign(
          ?alignObj car(last(alFrame)) ?alignHandle "lowerRight"
          ?refObj car(cuFrame) ?refHandle "upperRight"
    ) ; let
    ) ; procedure
  • MorrisDH
    MorrisDH over 2 years ago in reply to Andrew Beckett
    This is perfect!
