  3. RexCompile Buffer Length Exceeds
  • Replies 8
  • Views 7519
Henry Monro
Henry Monro over 2 years ago
Error* rexCompile: pattern for regular expression exceeds buffer length.
Is there any way how i can increase the length/size of the rexcompile buffer?
  • mbracht
    mbracht over 2 years ago
    Hi Henry,
    I don't think so - 512 characters is as far as I know the limit. Just out of curiosity - what pattern is it that exceeds 512 characters?
    You might also try the pcre version of rexCompile - pcreCompile(). Maybe it doesn't have that limitation.
    Max
    Andrew Beckett over 2 years ago in reply to mbracht
    I just did some experiments and pcreCompile allows a pattern which is a maximum of 32764 (slightly less than 2^31) characters long. rexCompile is ancient and very limited, so I'd encourage you to use the pcre functions as Max suggested.
  • Henry Monro
    Henry Monro over 2 years ago in reply to mbracht
    225-P1/225-P2/225-P3/225-P4/225-P5/225-P6/225-P7/225-P8/225-P9/225-P10/225-P11/225-P12/225-P13/225-P14/225-P15/225-P16/425-P1/425-P2/425-P3/425-P4/425-P5/425-P6/425-P7/425-P8/425-P9/425-P10/425-P11/425-P12/425-P13/425-P14/425-P15/425-P16/229-P1/229-P2/229-P3/229-P4/229-P5/229-P6/229-P7/229-P8/229-P9/229-P10/229-P11/229-P12/229-P13/229-P14/229-P15/229-P16/429-P1/429-P2/429-P3/429-P4/429-P5/429-P6/429-P7/429-P8/429-P9/429-P10/429-P11/429-P12/429-P13/429-P14/429-P15/429-P16/303-P1/303-P2/303-P3/303-P4/303-P5/303-P6/303-P7/303-P8/303-P9/303-P10/303-P11/303-P12/303-P13/303-P14/303-P15/303-P16
    This is the pattern
    i l'll try using it through pcrecompile()
  • Henry Monro
    Henry Monro over 2 years ago in reply to Andrew Beckett
    Thanks Andrew
  • AurelBuche
    AurelBuche over 2 years ago in reply to Henry Monro
    Hi Henry,
    That doesn't look like a regular expression pattern... (at least not in most common formats, like PCRE)
    If you want to match something that matches all the values between '/' there might be a smarter way to write it
    Cheers
    Aurélien
  • AurelBuche
    AurelBuche over 2 years ago in reply to AurelBuche
    If you want to match all the values between '/', a much compact approach, would be to use the following pattern :
    "(225|425|229|429|303)-P([1-9]|1[0-6])"
    If you want to match the whole string, this is not a regular expression, but a simple search for a string in another one
    _
    Also it seems you are tackling your problem the wrong way
    I don't know exactly what you are trying to achieve but you might want to use regular expressions to extract <num1>-P<num2> from whatever input string
    And then check if num1 belongs to '(225 425 229 429 303) and num2 is between 1 and 16
    Here's an example to do that (assuming the string is stored in the variable 'str') :
    (when (pcreMatchp "([0-9]+)-P([0-9]+)" str)
      (let ((num0 (atoi (pcreSubstitute "\\1")))
            (num1 (atoi (pcreSubstitute "\\2")))
        (and (member num0 '(225 425 229 429 303))
             1 <= num1
             num1 <= 16
  • mbracht
    mbracht over 2 years ago in reply to Henry Monro
    this is a regular expression of literal characters only - no quantifiers or character classes or anchors or anything that would require a regex engine. If you intend to compare this against whatever else you might as well make it a normal string and the use the equal() function.
    Also, if it's a sub-string of the full string you're looking for (and not a regular expression as Max said), you could use nindex() to see whether it is contained within the candidate string..
