  3. IC23.1 Studio version : Dropdown list for routePolydir
  • Views 6926
BartEbalobo
BartEbalobo over 2 years ago
Dropdown list for routePolydir is missing for EXL
What cause this and the solution for this?
    This (presumably) is the create instance or edit properties form for a device in a PDK. Which device is it, and from which PDK? Which IC sub-version are you using? I'm a bit surprised that the CDF for the device would be dependent upon a particular tier of the layout tool, but I guess it's possible. Either way, it would be an issue with the PDK and you should contact the foundry...
  • BartEbalobo
    BartEbalobo over 2 years ago in reply to Andrew Beckett
    PDK: 22nm TSMC
    nch_25od33_mac
    2.5V over drive 3.3V nominal VT NMOS transistor
    But it seems this happens in all devices.
  • BartEbalobo
    BartEbalobo over 2 years ago in reply to BartEbalobo
    After restart of the session the dropdown will fix and selection shown but after sometime, it will comeback. it is annoying and feels frustration.
    Andrew Beckett over 2 years ago in reply to BartEbalobo
    That's odd (I can't reproduce this). Is it affecting any of the other cyclic fields? It looks like some kind of form corruption rather than the choices getting messed up. What are you using for your display - are you running directly on Linux, or using VNC, Exceed Turbo X, NoMachine NX or something like that?
    I suggest you contact customer support (submit a support case after logging in).
  • BartEbalobo
    We are using Exceed Turbo X
  • BartEbalobo
    The problem that caused the error was identified, because of using lower resolution (1920x1030) on my display setting in exceed turbo x.
    need to use higher resolution like in the image to resolve the issue.
