  3. Control the y axis measurement spacing in Viva plots
  • Views 5946
SurajK
SurajK over 2 years ago
Similar to the "clip" function that controls the X-axis start, stop points in ViVA graph plots is there one similar to control the Y-axis?
For example: plot(clip(db(spm('sp 1 2)) 1G 2G)) plots a ViVA graph of the s-parameter analysis between ports 1 and 2 (S12) between 1G and 2G frequencies on the X-Axis.
Is there one to control the Y-Axis from 1db to 2db values where it only shows the portion of the graph between those values in Y-axis?
Can someone please help me out with this?
    Andrew Beckett over 2 years ago +1
    Rather than trying to clip the waveform (you could use the min and max functions for this), why not use the yLimit() (and xLimit functions) which will not clip but set the axis limits to show that portion…
    Rather than trying to clip the waveform (you could use the min and max functions for this), why not use the yLimit() (and xLimit functions) which will not clip but set the axis limits to show that portion of the curve?
  • SurajK
    SurajK over 2 years ago in reply to Andrew Beckett
    Thanks! Yes this helped.
    I used
    awvSetYLimit((awvGetCurrentWindow() list(lowerlimit upper_limit)
    awvSetYAxisStepValue(awvGetCurrentWindow() 1 10)
    To set the Y-axis limit and spacing respectively.
