  3. envSetVal list of "tools" that can be modified
  • Replies 7
  • Views 4525
SurajK
SurajK over 2 years ago
Is there a list of tools that envSetVal can modify?
For example I wanted to increase the font of the title of a ViVA graph that I plotted in a subwindow but don't know what the syntax/command for the same is.
Since I am using envSetVal to modify a couple of ViVA graph properties like lineThickness, lineStyle, colorBank, background etc., I assume envSetVal(tool "font" 'string val) can also change the position of the legend of a graph from left to above and increase the font size of the title but not sure what exactly I need to pass for the tool and val.
Can someone please help me out with this?
Thanks!
    Andrew Beckett over 2 years ago in reply to SurajK +1
    In the CIW - Options→Cdsenv Editor will list all the public tools and variables. envGetAvailableTools() will list the top-level tools (not the partitions or available variable names though). So that…
    There is no control to do this - you can't do it interactively (as far as I know - if you think this is possible, please describe how you do it interactively) - and there's nothing to change the behaviour…
  • SurajK
    I guess I found the commands to move the legend to above and increase the graph title font
    envSetVal("viva.graph" "titleFont" 'string "Default,16,-1,5,50,0,0,0,0,0")
    envSetVal("viva.rectGraph" "legendPosition" 'string "above")
    But still looking for the list of tools and values that envSetVal can modify.
    envGetAvailableTools() will list the top-level tools (not the partitions or available variable names though). So that may not help you.
    Also, typically the most important settings are documented.
  • SurajK
    SurajK over 2 years ago in reply to Andrew Beckett
    Thanks Andrew!
    This helps a lot.
  • SurajK
    Also Andrew Beckett can you please let me know the command to align the title of the graph to the middle instead of left?
    I gave envSetVal("viva.graph" "titleDisplayMode" 'string "elideMiddle") but it doesn't seem to be aligning the title of the graph to the middle.
    Can you please let me know if this is the wrong command?
    There is no control to do this - you can't do it interactively (as far as I know - if you think this is possible, please describe how you do it interactively) - and there's nothing to change the behaviour.
    If you read the documentation, this environment variable describes the behaviour when the title is too long to fit in the available space - it either elides from the middle (the default), the left or right - in other words, it omits part of the title and is replaced by "..." . For example, this long title:
    If the window is made narrower - it's eliding in the middle:
    The env var (if set before the window is created) controls if the ... are shown in the middle, the left or right end. It is not about justification of the title.
  • SurajK
    Got it. Thanks Andrew Beckett
  • SurajK
    Andrew Beckett So far I didn't find any direct command to format the title of the plot to the middle but I was able to satisfy my requirement through a workaround solution by doing
    addSubwindowTitle("                                                         Plot_Title")
