  3. leHiMerge blocks SKILL when unsuccessful
  • Views 5581
jaleco
jaleco over 2 years ago
How does one get past an unsuccessful call to leHiMerge in a SKILL script?
When there the function is successful (eg shapes are merged, return value is t ), the script continues.
When the function is not successful (eg no merge-able data is found) , it blocks the script from progressing.
I have tried evaluating the return value from leHiMerge.
I have tried muffleWarnings(leHiMerge).
I have tried cancelEnterFun().
I have tried envSetVal("layout" modalCommands 'boolean nil) prior to leHiMerge (because an unsuccessful return value stays in it as an enterFunction).
Below is what is displayed in the CIW when the function is not successful, and it remains stuck in enterFunction mode.
*WARNING* (LE-103092): The 'Merge' command was unsuccessful and returned the original set of shapes
because of one of the following reasons:
all the objects are of different type
all the objects belong to different groups
the objects of same type are not overlapping
one of the polygon type shape has more than 4000 points
the objects have a different mask color
To merge the objects, select valid sets of shapes where each set contains same
type of shapes.
    The best solution here would be to use leMergeShapes() instead of using the "Hi" function - that way you're not dependent upon any interactive behaviour of the function.
    If you really must use leHiMerge(), then you could use:
    hiEnqueueCmd("cancelEnterFun()") leHiMerge()
    This will enqueue the cancelEnterFun() so that if leHiMerge() doesn't accept the selected shapes, it will cancel the resulting enter function when the UI top-level is entered.
    However, using leMergeShapes() is a much better way to solve this in my opinion.
  • jaleco
    jaleco over 2 years ago in reply to Andrew Beckett
    Thanks Andrew,
    You are right of course, leMergeShapes() is a better way to do this, and is working for me.
    Thank you also for reminding me of the hiEnqueueCmd() function as another possibility when attempting to use something like leHiMerge().
    Very much appreciated!
