  3. Skill-Command for execute printing in the print preview...
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 21
  • Views 2938
Skill-Command for execute printing in the print preview menu
Mabr86
Mabr86 over 1 year ago
Cadence 23.1: By executing "plot" in the command-line, the following window appears.
Is there an skill command that can be used to start printing (red arrow)?
    0 Andrew Beckett over 1 year ago
    Which tool is this from? There are many releases with 23.1 as the number and no release or tool called “Cadence” - I suspect you’ve posted this in the wrong place but I don’t know where I should move it to as I don’t recognize the tool you’re using.
  • Mabr86
    0 Mabr86 over 1 year ago in reply to Andrew Beckett
    Cadence Allegro X 23.1 (S003)
  • mahimag
    0 mahimag over 1 year ago
    Hello Mabr86, I could not find any SKILL command which can start printing. We have axlCanvasPrintToPDF() which can be used to save as pdf.
  • Mabr86
    0 Mabr86 over 1 year ago in reply to mahimag
    Unfortunately, axlCanvasPrintToPDF() does not help me in this case. The print preview is opened by a script (.scr). The script is very old and extensive. In order to keep the effort to a minimum, a suitable skill-command or macro/script-command that I could insert at the appropriate place would be very helpful.
  • mahimag
    0 mahimag over 1 year ago in reply to Mabr86
    Hello Mabr86, currently the "Print" button is not scriptable. As well as there is no SKILL API available. There is a Cadence Change Request(CCR) 3016239 filed for this requesting this functionality.
    • Vote Up +2 Vote Down
