  3. Virtuoso AMS Simulation Error
  • Views 6399
SQ202407156826
SQ202407156826 over 2 years ago
Greetings,
I ran into this error " *Error* eval: unbound variable - _GLOBAL_amsEMSHandle " while trying to run a simple AMS sim in virtuoso. Does anyone have an idea what caused this issue?
My virtuoso version is ICADVM181, with INCISIVE152.
Thanks in advance.
Siyun
    Andrew Beckett over 2 years ago +1
    Siyun, Please see *Error* eval: unbound variable - _GLOBAL_amsEMSHandle netlist error in AMS Designer Also, why are you using INCISIVE152 - it's an obsolete 9 year old release, which was replaced by…
    Siyun,
    Also, why are you using INCISIVE152 - it's an obsolete 9 year old release, which was replaced by the XCELIUM stream (with many versions since, as it has a 6-monthly release cycle). ICADVM18.1 is also old (the last version was in 2020) - essentially the article I point to suggests using a version later than ICADVM20.1 ISR22. The problem occurs if you have a second maestro session open in the same Virtuoso with spectre as the simulator. I think that if you close that second maestro view then it will be OK (probably - this happened some considerable time ago so I don't have the time to test).
  • SQ202407156826
    SQ202407156826 over 2 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for the info. I updated the software and can now run AMS.
    Best regards,
    Siyun
