  3. how to get exit code !=0 when there is a skill error in...
  • Views 6236
how to get exit code !=0 when there is a skill error in a skill script?
marcelpreda
marcelpreda over 2 years ago
Hi there,
I have a script (python) which executes multiple skill scripts in parallel (postprocessing multiple simulation results in parallel to speedup the process).
There is a loop like below
virtuoso -nograph -replay "/.../batch_N.il" -log "/.../batch_N.log"
N is a counter: 1, 2, ...
Some skill batch files may crash and I would like to report the batches which were not successfully executed.
The problem is that always the exit code of the skill process is 0, even when we see the error stacktrace.
I would like to have an exist code !=0 , and not to parse the log.
The batch_N.il skill code consist of few load() statements and a call of one or two user defined procedures.
Is there a clean/simple solution to get exit code != 0 if there is a crash anywhere in the code?
Thank you,
Marcel
    Marcel,
    I assume you don't mean a "crash" but a SKILL error somewhere within the code. If so, you can surround the code with:
    if(errset({
      ... all the code
      } t) then
      exit(0)
    else
      exit(1)
    Of course, maybe you want this to be a generic wrapper, and then the bit within the errset could just load() the file you want (maybe using getShellEnvVar to retrieve the file name). Anyway, the principle is to catch the error and turn the success/failure into a suitable exit status.
  • marcelpreda
    marcelpreda over 2 years ago in reply to Andrew Beckett
    you read my mind: when I said "crash", I meant syntax error, unbound variable, division by zero or by nil, etc ...
    Luckily the crash already provide exit code != 0 Slight smile
    And your code example works like a charm, thanks a lot.
    At first glance the braces confused me, but checking the skill documentation [progn()] cleared it up.
    Best Regards,
    Marcel
